Question about Eiki Projector lamp Projector Lamp for LC-300
How to read the hours on an eiki projector lamp
Simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Posted on Jun 20, 2009
How can you view the amount of bulb hours for an Eiki LC-986?
The manual for your projector is found here:
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_x986.pdf
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to
move a red frame pointer to SETTING Menu icon (refer to page 37).
Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
Mar 03, 2011 | Eiki LC X986 Multimedia Projector
Where can i buy lamp for sanyo lp-z5 projector
You can purchase at www.Nextag.com (just verify the part number first) Sanyo Genuine Original 610-323-5998 Projector Lamp Video Accessories: Projector Lamps, Projector Stands - General Audio & Video Accessories: Carts / Stands Part #: POA-LMP94 more ..., POALMP94 Sellers Found: 6 Available Since: May 26, 2008
Lowest Price: $185.00
Average Rating: star-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.png Your Rating: ', Cancel:'cancel',AR:'Average Rating:'}); //--> (0 user ratings) No Reviews ' Write a Review Description 145W UHP - 2000 Hour Standard, 3000 Hour ECO Specifications Video Accessories Projector Lamps, Projector Stands General Audio & Video Accessories Carts / Stands Lamp Life 3000 Hour ECO, 2000 Hour Standard, 3000 Hour, 2000 Hour Manufacturer Part Number POA-LMP94 Brand Name SANYO Lamp Power 145 W Compatible Devices LCD Product Type 145 W UHP Projector Lamp, Projector Lamp UPC : 610074006343
Oct 08, 2010 | Eiki Sanyo Projector Lamp
In reference to the Eiki LC X999 projector
I figured it out by opening the bottom. The lamp was easy to change.
Jan 29, 2010 | Eiki LC X999 Multimedia Projector
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try www.projectordoctor.com
Nov 10, 2009 | Eiki LC-X1100 Multimedia Projector
How to check lamp hours on eiki lc - x50m
It does have a lamp timer but it is only accessible at start up if you hold down several buttons when you power the projector on. Eiki only supplies the info to dealers. I will see if I can post it later from my service notes.
Oct 19, 2009 | Eiki LC-X50M Projector
NO POWER
sounds like a heat sensor or fan problem. How old is the lamp, lamp hours etc.
http://www.youtube.com/watch?v=HvZ2DlVJ790
http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Sep 09, 2009 | Eiki PowerHouse LC-X4LA Multimedia...
How can i know the projector lamp age
go to the menu , check information or lamp timer . u will get the lamp hours.
u can also physically check the lamp for melted filament, white deposit on reflector of broken filament to confirm
Feb 08, 2009 | HP Digital Projector sb21 Multimedia...
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
461 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
