Question about Tascam DR07 Portable Digital Recorder
Dr 660 reinitiates after playin a song
When playing a pattern or song for 5 around seconds drum machines reinitiates. Any idea why? I dont get the battery low message.
2 Suggested Answers
  • 189 Answers
SOURCE: Drum track
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
http://www.tascam.com/details;8,16,5,19.html
Posted on Feb 26, 2008
I have a 1990 Alesis SR16 drum machine which has not been switched on for over 10 years. I now wish to use it again but all data including factory presets have been lost. How do I re instate them
How do I reinitialize SR-16?
Power on while holding: "ERASE" and "PLAY".
Evidence: All User songs and patterns will be empty.
Note: Clears memory
Clears the SR-16's User Songs and Patterns, but leaves the Preset Songs and Patterns intact.
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
Nov 08, 2014 | Alesis Sr 16 Stereo Drum Machine
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Sep 25, 2014 | Alesis Sr 16 Stereo Drum Machine
I was needing the instruction manual for a BOSS DR 550 MK II Drum Machine
The DR-550 MkII is the upgraded version of the venerable, original DR-550. ... Also, as in other drum machines in the DR-series, you can chain patterns to forms songs - In the DR-550 MkII, up to 8 songs ... Boss DR-550 Mk II manual. Available ... www.synthmania.com/dr-550mkii.htm
Just checked this site. I am sure this manual is the one you want
Feb 20, 2012 | Music
How do i transfer patterns from one sr-16 to another?
There are two ways. 1st way is to use the tape out and a 1/8 to 1/8 cable connected to a tape recorder or computer. And use the send thru tape function. while recording. then on the second one reverse the cable. And use the tape in function. The 2nd way is to copy beat for beat in the quantize mode by hand onto paper, the reprogram each sound(beat) back into it.
Aug 18, 2011 | Alesis 16 Bit Stereo Drum Machine System
Drum sound distorted
Try a factory reset:
alesissr16logo53x41.jpgrmidialesissr16logo53x41.gif Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Jun 06, 2010 | Alesis Sr 16 Stereo Drum Machine
    Music plays for 10 seconds then swicthes to next song
    my last MP3 did that...its like a demo mode...sorta it gives you a taste of all the songs that are there...so you know what you have on ur mp3 maybe ur situation is different...i dont know...but thats all i could think of
    May 16, 2009 | GPX Audio Players & Recorders
    Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
    Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
    Mar 03, 2009 | Boss Micro BR Digital Recorder
    Drum track
    Feb 13, 2008 | Tascam 2488 Portastudio Multitrack...
    Tascam DR07 Portable Digital Recorder Logo
    Top Tascam Audio Players & Recorders Experts
    Sam Palermo
    Sam Palermo
    John
    John
     Grubhead
    Grubhead
    Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
