Question about Bialetti Mokona Espresso Machine
Won't steam or heat up
The delivery light does not come on ,or steamer won't work or heat up ,the pumps is ok
Delonghi stiromeglio master steamer iron , why no steam to the iron?
If you have been using tap water it may be plugged up with minerals.
Sep 13, 2014 | Coffee Makers & Espresso Machines
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
Hi, We have just bought a DeLonghi Caffe Treviso. We are not able to get any coffee/liquid to drip out of the filter holder. The problem seems to occur when we are trying to preheat the machine, for...
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Dec 15, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Steamer not working at all. water tank / electrical outlet all check ok/plugged in and not doing anything
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Lights on but no steam and getting hot
In order to produce steam, you have to "pump" the steamer. After it heats up, pump it while moving it back and forth on the floor while mopping - it takes a few strokes to get the steam really rolling. I love mine - ;)
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Bialetti Mokona Espresso Machine Logo
27 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Bill Boyd
carlos parada
carlos parada
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
