Aiwa lp 3000 - Audio Players & Recorders
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
I just purchased a used weber genesis 3000 grill that was converted from LP to NG. At least it has a NG hose and fitting. I connected it to my NG line but it barely lites. It seems to me that only the hose...
you have to change the orfices as well on this not just the line the burners you can use try national energy they are on line they do spares or calgary bbq centre they should have what you need.
Sep 24, 2011 | Grilling
I need a replacement needle for model px-e860u, where can I purchase them?
I found the following places to purchase online:
LP Tunes
LP Gear
ioffer
Anderson's Music
Many of these places also sell other parts for your turntable - a common replacement part is the drive belt. You might want to buy that too - and have it shipped at the same time.
Please rate this reply - good luck!
Dec 07, 2010 | Aiwa Audio Players & Recorders
I have a 48" GE Monogram 4 burner with griddle gas/ duel fuel range (ZDP48N4GD1SS) that was set up for natural gas. I need to convert it to LP but the parts website doesn't show a conversion kit for this...
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Aug 19, 2010 | GE Monogram ZDP48N4GHSS Stainless Steel...
How do i get it to work? sorry but this is my first time using a record player
most of today's receivers dont have the jacks for phonos...you will be able to plug left/right plugs into aux/cd (unless you are using a power amp) . is your phono equipped with the needle (cartridge) also? yes, then you are ready to play a LP/Album...turn volume down on amp or receiver place LP onto turntable needle on switch source selector to what you plugged into turn vol up slowly and enjoy
Aug 13, 2010 | Aiwa PX-E860 Turntable
The lp speed and 45 speed works but the rpms is just too fast or just too slow, which changes the pitch just enough tobe out of tune. with out a strobe adjustment can the rpm speed be corrected and how
get your unit serviced by a reputable service centre or risk killing it with the strobe controller,your choice
They both work differently and Im sure they are different voltages too
the strobe will introduce a clicking noise to your beautiful sound,not very good at all
If you enjoy you music like I do then do it properly,
ask fo a quotes first or search for a replacement.
Hope this helps,please rate me thanks
Apr 27, 2010 | Aiwa PX-E860 Turntable
I own an AIWA Stereo Synthesizer Tuner which has a 3 speed turntable, double cassette deck and CD player. Just had the CD player cleaned and it works fine but the stylus for the turntable is shot....the...
Unfortunately without seeing the actual needle or cartridge, it is just about impossible to provide you with a part number. Where are you located? Needles are still available and I sell them all the time. I will try to locate the "standard" part number for your model, but there were often different setups available. Is there any way to provide a photo of the one you have now?
Check the balance of the tonearm as well. If there is not sufficient pressure on the needle, it won't track the record correctly either. Please note, the you shouldn't put too much pressure or you will wear the record.
Please keep us posted.
Thanks,
Dan
Sep 21, 2009 | Aiwa Audio Players & Recorders
I would like to know coustmersurvice phone number
Being an Aiwa service man, may I know problem in your Aiwa receiver. For your information, Sony is dealing Aiwa too because its subsidiary of Sony. You can ask Sony for Aiwa service. For details, click on Sony Official Information page. and here is Aiwa Support page.
Regards,
Sep 06, 2008 | Aiwa Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
