Question about Garden
Caseing *** for garden tec pull cord chain saw
  • 17 Answers
SOURCE: Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Posted on Jan 03, 2009
  • 583 Answers
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Posted on Aug 04, 2009
SOURCE: Ryobi 40cc chain saw, pull cord won't turn engine
If it has ball bearings in the rachet mechanism they may be sticking and need cleaning so they move freely.!
Posted on Aug 14, 2009
SOURCE: Ryobi 40cc chain saw, pull cord won't turn rotar assembly
I had the same problem with my 18 inch Ryobi saw. The problem is the tabs that engage the recoil to the flywheel are of poor quality steel and they bend out of position. The end result is when you pull tyhe rope it just jumps and wont start. Eaven the new parts do the same thing. Simple soultion is remove the recoil starter four screws require a torx bit or a flat screwdriver. after your remove the recoil starter using a pair of pliers bend the two tabs upwards untill they are not quite straight up (about a 80 degree angle be carefull not ot brake the tab off) once you have done this remove the center nut that holds the flywheel on. the silver pins that hold the tabs in position need to be punched out but remember how they go back by doing only one at a time and remember how the spring is installed. Turn the flywheel over and using a punch and hammer remove the pins. Put the tabs in a vise to hold them sucerly clean the steel as best you can on the inside of the bend. Fill the bend with brazing rod or coat hanger if you haven't got any brazing rod avilable. You don't have to com;leatly fill the bend but put enough in there to suport the tabas so they can't bend agin. Reassemble the saw and you're done. Mine works great now, better than new. This problem isn't limited to recon saws only, mine is a new saw and I still had the problem. Good luck herbdogs
Posted on Sep 07, 2009
dontbother10
  • 2220 Answers
SOURCE: my 110 model chain saw sucks chain oil back into
Did you adjust the oiler? To far CW might cause this. The automatic oiler is driven by an impulse line from the crankcase. If the piston assembly is to deep or has failed there is a direct line into the crankcase.
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Mac 110” 600016C may also be a _# instead of letter 600016_03) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Mac 110” IPL number = 11-600016C). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
This is a little complicated so I am going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “11-600016Letter or YourDashNumber”
Every Oil Pump will eventually cross to
Entire pump assembly:
219989 Kit Pump Assy (Oil) $9.29
O-ring
110653 O Ring $0.75
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
I have found McCulloch parts here I can get no where else and they are reasonable.
You can download a complete parts breakdown for your saw here using the IPL constructed above:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Please see if the parts you need are available here. They were not when I ordered them but it is a nice way to say thanks for providing the IPL. I hope you find this helpful.
Lou
Posted on Dec 19, 2009
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Good morning,I have a homelite super2 chainsaw,the pull string doesn't roll back after pulling it to start... what can be wrong and how do i repair it. thank you.
recoil spring or internal movement worn
ask you chain saw repairer/ part supplier
you might be able to get a used off the shelf bolt on replacement or have to pull yours apart
by the pictures
not an easy pull apart repair
new coil spring can let go while refitting it
recoil rope holder is plastic and set into the side casing
looks like you have to undo that side casing of the saw including the rolled hold handle
index-00nkgcv3qozdkgxfkoitxhz4-2-0_0.jpg44-00nkgcv3qozdkgxfkoitxhz4-2-2.jpg33-00nkgcv3qozdkgxfkoitxhz4-2-3.jpg
Mar 07, 2017 | Homelite Garden
Gardenline
gotta google it to find yourself a parts source. or take it to the saw shop for a looksee
Apr 13, 2014 | Garden
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
My chainsaw starts when there is no bar and chain on it but when I put the bar chain and side casing back on tighten the chain and pull the starter cord it is hard to pull and then the chain goes loose...
Have you just replaced the chain?
If so there is a possibility the chain and drive sprocket don't match causing the engaging spurs to ride on the sprocket teeth
Jun 24, 2010 | Husqvarna Chain Saw 20" Bar
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Aug 14, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Hi i have a Poulan chain saw and it will not
well there are generalloy two issues with any motor. SPARK and FUEL
Remove the plug and hold it near the entry point of the plug hole so it earths to case. Pull starter cord and see if the plug has a stong spark.
the should also be some wetness on the plu indicating fuel is pumping. Place finger over the plu hole and pull cord avoiding any spark but check the amount of pressure in cylinder. The pressure should be stronmg enough to push your finger off the hole
Replace plug and open the air intake and spray some AEROSTART into air intake pull start cord. If this does not cause it to attempt a start, I would suspect the coil is fused and will need replacing
Aug 11, 2009 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
