Question about LG Dryers
LG DLEO332W Dryer -- tub rubbing the sidewall. When running empty sounds like a coin in the tub. Popped the top. Belt is in place. In front of the belt circling the tub is a thin 3'' wide rubber/plastic strip(actually 3- 3x24''strips). To the back of the dryer the same set of strips has worn off against one sidewall and now the drum rubs the sidewall. Don't know if this took 4yrs of rubbing or dryer wall dented moving 6mo ago. What is function of strips? Part# since I cannot find strips in manual? Is it ok for tub to be shifting side to side slightly(1/4''?) as it rotates- or does this need an adjustment? Thanks, Mike A
    Top Expert:
  • LG Master
  • 41,738 Answers
Drum rollers could be worn or defective
Posted on Apr 10, 2017
  • 262 Answers
SOURCE: Maytag dryer neptune felt at rear of trum came out
you have to buy a new one if the felt seal is still good use contact cement on the drub and seal to put back on with need any more help let me know
Posted on Jan 17, 2008
Timon90
  • 126 Answers
SOURCE: Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Posted on Jan 23, 2008
  • 221 Answers
SOURCE: Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Posted on Apr 06, 2009
  • 161 Answers
SOURCE: the dryer makes a high pitched sound when running.
the drum rides on a felt seal around the door opening it could be worn out or some thing could have gone through one of the holes or possibly the bearing
Posted on Aug 30, 2009
  • 2468 Answers
SOURCE: My dryer makes a weird noise when running, kinda
depending on the make and model of the machine the drum glides or rollers need replacing,to accomplish this you need to remove the front cover by removing toe kick panel screws and lifting up on cover,you get instructions with the glides or rollers on replacement when you buy them
Posted on Jan 25, 2010
I have an LG Electric Dryer Model No. DLEO332W. It runs fine on ultra low or low heat, but if in the middle of the cycle I turn it to medium, medium high or high heat it cuts off.
There is a hi-temperature limit switch in the heating area that may be the issue. It can be manually reset but hard to get to. Top off, control panel off, front off.
Dec 03, 2017 | LG Dryers
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 | Dryers
My dryer makes a clunk sound twice per each revolution. I thought maybe a bearing but all seems tight???
sounds like coins are in the tub vanes...take top off dryer and remove screws that hold vanes in place...maybe coins under the vanes....seen it hundreds of times in 40 years
Sep 18, 2011 | Frigidaire FEQ1442ES Electric Dryer
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
My dryer is making a loud rubbing sound....the dryer shell is not moving funny or anything...and I smell burning..how do I check the belt in amana 1983 dryer
front glides and felt are bad and rubbing metal to metal. get model # go to searsparts.com and look it up. 2 screws on lower front removed (unplug dryer) pull bottom of front out and up till top clips let go be careful of door switch wires. label and disconnect them. check felt seal for damage. check glydes on towers holding drum up. it could also just be s coin or somthing stuck at drum edge.check the blower wheel make sure it's not stripped out or have somthing stuck in it.
Feb 17, 2010 | Amana Dryers
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Old whirlpool mini dryer
Those are front tub supports that keep the tub from scraping.Unless you start hearing a rubbing or scraping sound your dryer is ok.Just keep a ear open for awhile for any scraping sound.If you need help in the future with anything ,Im more than happy to help you.
May 24, 2008 | Dryers
Coin stuck in the tub baffle
on top of the machine where the filter is there are 2 screws`remove.gently pry up on the top front of machine.it should pop up. rotate tub till your coin gets to the top .you should see the screws you need to remove .
Feb 24, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
264 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
