Question about Philips FR965DHT Receiver
PHILIPS PT tv comes on shortly and blows BUT11APX
Tv wont turn on
loud noise ? ! just indicate that the main power supply capacitors are bad, or sometimes is just the ceramic filters.
undo the back and check for any blow capacitor or burned components.
the new power board cost 139.99 on ebay
http://cgi.ebay.com/Power-Supply-LJ44-00117A-PS-425-PH-Philips-42PF9631D-37-/260597950481?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3cacd92811#ht_500wt_928
if you dont want to fix your TV, let me know cuz i will buy for parts, write me to
fosg2000@gmail.com
May 18, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
Jan 19, 2010 | Philips Televison & Video
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not...
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
Nov 15, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Philips 43P8341 will not turn on
sounds like your two convergence ICs are shorted out, plus you probably need two 6.8ohm resistors ICs are part # STK392-120
should be installed by a trained repairman cost about $300-400
Aug 17, 2009 | Philips 43P8341 43" Rear Projection...
Blows Fuses
Hi
They have so many reasons why blown fuses in TV... all you have to do is to check the shorted semiconductor like regulator and drivers..
Thanks!
Feb 24, 2009 | Philips 27PT5441 27" TV
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Jan 29, 2009 | Televison & Video
Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Jan 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Philips TV Model No. 21 pt 2622 - 69 r Power side is not work
Hii...
What is Philips TV model " no.21 pt 2622-69 " ?
Thank's
[Vrya]
Feb 23, 2008 | Televison & Video
Tv won't turn on manually or with remote.
The water shorted out something in the power supply. If it got into the high voltage section, then probably this circuit has shorted.
Stargazer
Oct 26, 2007 | Philips Magnavox 20MT133S 20" TV
Philips FR965DHT Receiver Logo
23 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
