Question about IBM ThinkPad Computers & Internet
EpePc has been corrupted (error 92h) Windows 7
3 Suggested Answers
rhojojoe
  • 93 Answers
SOURCE: safeboot corrupted (error 92h)
Safeboot corrupted. Run the Recovery Console by doing the following;
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
    For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
    For information about a specific command, type help commandname at the command prompt, and then press ENTER.
  6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Posted on Jun 24, 2010
  • 26 Answers
SOURCE: epepc has been corrupted error 92h
come to my site and chat so we can see to the problem
http://helpwithpcs.webs.com/
go the chat room
Posted on Mar 15, 2013
Fix error 0x800704b3
This error is usually referring to a corrupted profile, you should try creating a new user to see if it resolves the issue. Instructions can be found here: http://windows.microsoft.com/en-us/windows/fix-corrupted-user-profile#1TC=windows-7
Feb 14, 2015 | HP Pavilion Computers & Internet
0xc000007b error windows 7
Hard drive or data error. Try and run chkdsk/f
Generally just running chkdsk/f will fix this error. its normally down to bad sectors on a failing hdd corrupting data.
if your hdd shows more than 1% errors get it replaced as its failing. if its just the odd soft error then full formatting. may solve the problem if chkdsk/f doesn't.
Jan 29, 2014 | Computers & Internet
Epepc has been corrupted error 92h
go the chat room
Mar 15, 2013 | HEWLETT-PACKARD EliteBook 8460p Notebook
Safeboot corrupted error 92h message
run the receovery again and wait for the process to finish before removing the cds.
Sep 26, 2012 | Toshiba Satellite M55-S325 Notebook
Have corrupted files on my acer travelmate 2300
So are you running xp or windows 7, either way you could put in your operating system discs and go through the prompts and repair computer, windows 7 will find error and correct as will xp, but with xp if you choose repair you will lose all updates and servicepacks, or you could try these instructions on the link below
http://support.microsoft.com/kb/307545
Cheers
Sep 24, 2012 | Acer TravelMate 2300 Notebook
Corrupted windows 7 profile
Visit this link:
http://windows.microsoft.com/en-US/windows-vista/fix-a-corrupted-user-profile
To avoid such kind of errors use a system utility software like RegInOut to optimize your PC.
Hope it works for you.
Dec 11, 2011 | Computers & Internet
Error: code0x80070017
When you install Windows 7 (or Vista) you may get the following message:
Error 0x80070017 Windows cannot copy files required for installation. These files may be corrupt or missing. Make sure all files required for installtion are available, and restart the installation Error code: 0x80070017
This can be displayed with error code 0x80070017 or error code 0x80070570 in Windows 7 or Vista
The cause is very simple and you can probably guess from the error code in the screenshot above. The cause is that Windows cannot verify the files.
Simple Solution
  • Burn or get a new copy of the disk (Burn at a slow Speed 2x and use a quality media like (Verbatim)
  • Or if you have a current Windows installation you can install from the hard drive or from a USB drive
Check out my article on installing Windows 7 using a USB Key USB-stick-from-windows-xp/">Install Windows 7 from USB Drive
Dec 25, 2010 | Computers & Internet
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Jun 11, 2010 | HP Pavilion Slimline s3620f Desktop
Help on reformating pc!!!
Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
Jan 21, 2010 | Acer Aspire T310 PC Desktop
Computers & Internet Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
