Question about Avanti "W757 Washer"
Avanti w757-1 water level switch indicator - Avanti "W757 Washer"
I have a Avanti water dispenser wd50 and the cold water faucet side faucet not dispensing
Hallo
The solenoid at the back of the fridge is suppose to get 230V when the leaver is pressed test the currency and if you het 230V the solenoid is faulty and needs to be replaced other wise its the switch on the leaver that's faulty.
regards
May 26, 2016 | Avanti Refrigerators
My avanti w798ss1 take in water then its does do anything
check the water pressure switch in the panel. it has a clear plastic tube in it if u remove the tube place a small pc of tubing into the switch while u have it on wash cycle, then blow into the tube connected to the switch if it goes into wash u may have a bad tube clogged or a pin hole in it. if it does nothing u have bad water pressure switch diaphfram
Mar 07, 2015 | Avanti Washing Machines
My avanti w798ss1 take in water then its does do anything?
Check the water pressure switch in the panel. it has a clear plastic tube in it if u remove the tube place a small pc of tubing into the switch while u have it on wash cycle, then blow into the tube connected to the switch if it goes into wash u may have a bad tube clogged or a pin hole in it. if it does nothing u have bad water pressure switch diaphfram
Mar 07, 2015 | Avanti W798SS1 21" Portable Top-Load...
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
Avanti W797 Combo Washer and Dryer............Does not fill with enough water to wash clothes. It will runn the cycles with some water, but clothes do not all even get wet????? How can I correct the...
I have this problem too. Called the repair man out to the house & he just told me it was set at the factory & there was nothing he could do. I discovered if I held the water level knob between the settings given, water would run to the level I wanted as long as I held it in place, but I don't know if this does any damage to the machine. So I don't know if you want to try that or if it can even be done on your model???
Feb 21, 2012 | Avanti W797 12 lbs. Top Loader Fully...
No instructions came with my Avantis 100. Mode. 1829/A 3.12 104. I have used it for several years, just guessing and hoping I am using it correctly. Would you have information on it.
If you have been using it for several years, you are using it correctly already. the fact that it still operates indicates that you use the proper sort of water in it (not using distilled water is the number one cause of failure in irons). The information available for the Avantis is really generic and will not add to your success, I assure you. Iron on! Farmerbear at FixYa.com
Sep 30, 2010 | Tefal Avantis 100 Iron
Hot water overflowing
thats a sure sign of a bad water valve contact avanti there a good company they may send you a new one
Apr 01, 2008 | Washing Machines
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
Avanti "W757 Washer" Logo
18 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
