Question about Mitsubishi WD-60735 Projection Television
Picture is very slow to come on and drak - Mitsubishi WD-60735 Projection Television
China tv boad drak picture
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 20, 2015 | Televison & Video
Drak line on screen what to use to get off
LCD panel is bad, part is not available
Sep 26, 2013 | Protron PLTV-3750 Television
Ir 3300 the print out is dark
keep the develop setting between -30 to +30.If the image is too dark then chck the toner you are using as in most case it is the culprit.
Apr 19, 2012 | Office Equipment & Supplies
The Outer screen is blank (drak)
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 10, 2010 | Nokia E90 Smartphone
I see only a black screen drak
i think u could not adjust web cam lence. you can adjus in forants parts of camer by rotting.
Jul 14, 2009 | Logitech Webcam
Picture too dark
Hi kseguin
Your TV has internal problem @ video stage on the circuit
But you may try to apply resoldering on the circuit board near flyback and CRT circuit board.
Apr 14, 2009 | Panasonic CT-34WX52 34" TV
The screen is drak as if the black light went out in it.
If you can use a flash light to see the picture than your blacklight is out.. order one from ebay... farily easy change out
Dec 01, 2008 | Computers & Internet
How do i get good pictures when taking it during the night and able to focus the camera to get the real nature color of the drak
You'll have to use a tripod to get good shots at night, because in order to get a lot of colors in your photo, you will have to set it for long exposure times. Good luck, and have fun!
Aug 16, 2008 | Nikon Cameras
Mitsubishi WD-60735 Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
