Question about Envision G19LWK Monitor
Sound how to get sound from monitor speakers
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
No sound, other monitors have a input jack for sound but not this one.
Some monitors have built-in speakers and others do not have them.
In this case you need to purchase separate external speakers to connect into your computer. If your computer has audio output for surround sound, then you can buy 5.1 surround sound speakers. These will have 2 front speakers, 2 back speakers, a center speaker and a sub-woofer speaker..
Jun 04, 2010 | LG Flatron L2320A 23" LCD Monitor
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
No sound on monitor
First off is your monitor has any speakers on it or capable off producing any sound? Not all monitors comes with speakers attached to it.
Jul 03, 2009 | ViewSonic Monitor Lcd 22in Wide Va2216w...
Cant get speakers on my monitor to work after I unhooked external
IF you have xp go to control panel/sound,speech and audio. You will see a drop down choice that says change speaker settings. Click on this. Then under the tab that says speaker settings hit advanced. Then select the sound scheme that says monitor with stereo speakers and apply this. Assuming you still have a functioning sound driver this should return it to the monitor speakers. Hope this helps.
Mar 29, 2009 | HP (400745-001) Sound Card
Can't get sound through speakers/headphones
You need to connect the speaker wire coming from the monitor to your PS3 if you want the sound to come out of the monitor speaker. Normally, you need an adapter for this.
Mar 15, 2009 | Computers & Internet
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
No sound from monitor speakers
The monitor must plug into the PC as the external speakers did.
Apr 16, 2008 | Westinghouse L1928NV Monitor
Viewsonic Monitor sound problem
Hi check the sound cable hasn't fallen out or come loose from the back of the monitor. After this reinstall the drivers for the monitor you will be able to download them from viewsonic if still not working then the speaker jack or speakers are faulty.
Hope this helps
Thanks J
Jan 20, 2008 | Computers & Internet
Envision G19LWK Monitor Logo
16 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
