Question about Whirlpool LBR4121JQ Top Load Washer
Whirlpool LSR8233eq top load washer won't spin most of time
Spins some of the time but not often, wife says if you let it cool off for an hour or so and then turn switch to spin it sometime will catch and spin - pumps water out, lid switch kills motor if lid opened - can hear motor running with lid closed - has new coupler installed - new spin pawl in transmittion - yes I opened transmittion, replaced worn spin paw #63341 - inspected other parts for wear - same problem as before replacing pawl - inspected brake and cleaned - washes, agitates, water in and pumps out just won't spin - HELP have to go to mother in law to wash close
  • 1 more comment
  • dalefries Jun 20, 2009
    Thanks you for quick reply - is there a assembly diagram on line - I think I got everything back together OK - not sure of washer that sits on top of brake - with transmission and shaft out of washer there is a slip on split ring that locks washer onto shaft above plastic fingers that hold brake housing - washer is like a deep dish plate (pie pan with rim)- not sure if it went on indention up or down fits either way - good diagram would sure help.
    Upon first start up after reassembly worked great - washed and spun for two loads - told wife fixed - she did load and it didn't spin - tied of mother in law visits to use their washer - HELP
    Thank you but picture did not come through just box with "X" can you email picture to dalefries at att.net dalefries@att.net
    Thank you
    President:
  • 1,136 Answers
Hi, It sounds like your spin basket drive is going bad. Even tho you cleaned the brake, the pads get worn down enough they will not grab. The only other thing I can think of is the bloch that sits on top the basket drive shaft and lockes the inner tub. Sounds like you have done/checked everything else.
Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
  • 1 more comment
  • Victor
    Victor Jun 20, 2009
    The washer sits on top of the E-clip. I will look into a picture for you.
  • Victor
    Victor Jun 20, 2009
    Here is a picture
  • Victor
    Victor Jun 20, 2009
    ok, I sent pic to your email
Stops during rinse cycle and won't pump the water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
The washer quit spinning, I can get it to work in wash mode but when it comes time to spin out it won't do anything,
themobilian_2472.jpgIf it won't puthemobilian_2473.jpgmp out the water or spin that is the lid switch. If it pumps out the water but does not spin then that is the motor coupling. How to get into the machine.
How it works: 4 videos and a service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2011 | Whirlpool LSR6334LQ Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My washer will not go into spin cycle my wife says she can hear the motor running but it isnt spinning
You might wanna check the belt. It might have gone out of the spinner rail or is broken.
Sep 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
Top load Whirlppol Ultimate Care II Top load washer will not spin, makes the noise like it should be spinning but doesnt spin...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
We had the same (plus another) problem with an old Kenmore top load, direct drive,neutral drain washer.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Problem 1. Major gear sounding grinding during spin mode. Major vibration also.
Problem 2. Spin problem. Most times the washer would drain but wouldn't spin unless the lid was raised and lowered. (According to wife, this problem has been on-going for two years).
After checking motor coupling (a bit worn but intact), drive block (you don't need a spanner wrench to remove it, a 12 - 14 inch pipe wrench works great) which was OK, clutch, seemed OK, we determined that the problems were in the transmission.
Two options, 1 spend $150 plus for a transmission.
2. Open it up and see if anything seemed seriously bad.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
the first problem seemed to be related to the agitator cam and cam follower not raising the agitator gear high enough (probably less than a 1/16th of an inch) above the agitator cam.
Found the right part number (Whirlpool part # 62580 / 81) which includes both the cam and follower. Bought one for about $10.50, installed it, put washer back together and problem 1 was solved.
Looked again at parts list and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
Those cams/gears etc. keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
Whirlpool parts list for commercial washer, consumer washers are basically the same.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
With apologies to American-Appliance.com, see their description of how to tear down a Whirlpool direct drive.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Sep 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Does not spin
The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
God Bless and Happy New Year.
Dec 31, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool LBR4121JQ Top Load Washer Logo
330 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
