Question about Delta & Victorian 5 Spray Showerhead
How to open Triton shouuwerhead to clean? - Delta & Victorian 5 Spray Showerhead
AS2000XT triton shower problems
1. make sure there is water getting to the triton control & pump
2. make sure there is power available to the pump
3. if 1 & 2 correct, then check to see if shower head needs cleaning to open the spray holes. if yes then use vinegar solution.
4. if 1, 2 and 3 do not fix problem, there is something wrong with unit and it may need to be repaired or replaced.
Mar 20, 2014 | Home
Korg Triton Studio LCD malfunction! Please need help badly! :(
Where can i purchasea lcd for my korg triton studio
May 28, 2012 | Music
Magellan gps Triton 300 series Jamed up; Reads when turned on ; Internal Error Your Triton has encountered an unexpected error and must shut down. Please wait while your data is saved.
The problem with your magellan triton is that there is a file missing in the support file that allows the triton come on properly hereby leading it to jam.
The solution is for you to get your triton connected to a computer, then you back up the software on the computer, format the triton then you restore the software and maps on the triton. Then your triton will be in good condition once again.
Hope this information helped.
Jan 03, 2011 | Magellan Triton 300 Handheld GPS Receiver
Mitsubishi Triton air bag light "ON" and the error cose B1401 F ABG(1) DR Squib open. May I know how to solve.
Dec 08, 2010 | Mitsubishi Eclipse Spyder Cars & Trucks
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
Triton 400 GPS locks up on start up
Somehow you have corrupted the internal software and need a full repair.
Sep 16, 2008 | Magellan Triton 400 Handheld GPS Receiver
I have a 2000 Triton 2.8 diesel mk 4wd regularly serviced that blows black smoke constantly under power & uses excessive fuel
does your regular service includes the injection pump being brought down for cleaning and maintenance?
it is an injection pump problem. inside the injection pump are valves and strainers that are not accessible for regular users. they could only be cleaned or replaced by these people who work with injection pumps and they would calibrate the injectors also so that it would not be blowing black gas and uses excessive fuel.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Pickup Cars & Trucks
I have a Triton topaz 100i shower, recently the water would not heat up, when i opened it the thermal cut out was in pieces, i have now replaced this, but now, no water comes out at all. If i short the...
its the thermal cut-out... when there is something like limescale that causes the temp to get over 50c - the thermal cut out is
activated... it has to be replaced... which u can buy it from triton or get an engineer out to replace it
tip... make sure u clean the shower and shower heads often with a limescale remover....
Apr 22, 2008 | Heating & Cooling
Delta & Victorian 5 Spray Showerhead  Logo
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
