Question about 2wire Wireless-G 802.11g ADSL Gateway
Can aztech 1016 be a 2nd router - 2wire Wireless-G 802.11g ADSL Gateway
LAN connection shows "Unidentified network" when connecting through Aztech Homeplug
Check the network Cable type which you used to connect the Homeplug to Router, Check with both the type of cables (Straight and Cross) and Let me know if it works
Mar 06, 2014 | Computers & Internet
HOW TO DISCONNECT WIRELESS MODE FROM MY AZTECH HW550-3G ROUTER?
You will have to go into the router and turn the wireless off. You will need your ip address of the router and the default userid and password to get into the router. The user manual will give you all that.
Get online and got to www.google.com In the google search box type: "Aztech Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals.
Jun 03, 2012 | Aztech HW550-3G 300Mbps 802.11n Mimo...
How to disconnect wireless..?
You will have to go into the router and turn the wireless off. You will need your ip address of the router and the default userid and password to get into the router. The user manual will give you all that. Get into the router an go to the wireless tab or wireless settings and turn it off. Or you can change the wireless password.
Aztech hw 550-3g not transmitting signal
I was having the same router Aztech HW550 3G, exactly the same problem. Bought from Etisalat, UAE, completion of 12months the transmission signals were not happening. Till now I could find anything out in order to getting it working...
Feb 04, 2012 | Aztech HW550-3G 300Mbps 802.11n Mimo...
How to connecting Aztech modem DSL600E with Router linksys WRT54G
1.connect port 1 from the Aztech to the Linksys WRT54G Wan"
Login to the linksys and release/ renew ip
2. once IP is obtained then you should be able to connect.
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
47 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
