Question about Salton Melitta MEU45 Stainless Steel - Coffee Urns
How much water for 40 cups of coffee - Salton Melitta MEU45 Stainless Steel - Coffee Urns
Proctor silex manuals
I use 1 tablespoon for each cup (8 oz) of water.
Aug 13, 2014 | Proctor Silex Commercial 40 Cup Coffee Urn
My b-40 Keurig doesn't make coffee it draws the water and despences it back into the water well. It doesn't come thru the coffee pod.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 05, 2011 | Keurig Elite B40 Coffee Maker
How much coffee to add for 20, 40, 60 cups of coffee in the 60 cup DeLonghi coffee urn?
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
heatman101
Apr 30, 2011 | DeLonghi BAR 140 Espresso Machine
How to measure coffee for 45 cups. Also is a filter needed.
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
100-CUP MODEL #33600
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
Mar 09, 2011 | West Bend 33600 Coffee Maker
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
I Love my Mr Coffee, it used to be ready when I got up, now it takes 40 minutes for 12 cups to brew, is there something I can flush the lines out with or what?
It is likely that it is clogged up with scale. If you live in an area with hard water, especially well water, the calcium in the water is left behind when the water steams away. Take about a quart of regular vinegar and pour it into the tank you normally pour the water. Let it stand about 30 minutes and then run a regular cycle as if you are making coffee except without the coffee grinds in the brew basket. Keep pouring fresh water through it until you not longer smell vinegar coming out. It will put it back into normal running condition.
Sep 21, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
How much coffee to use for 55 cups
Follow the directions on the brand of coffee you buy. Usually 1/2 cup of coffee for 10 cups. Ex: 2 3/4 cups of coffee for 55 cups. 1 cup for 20 cups. 2 cups for 40 cups. Hope this helps.
Jul 03, 2010 | Faberware 12-55 Cup Coffee Urn
When I put 12 cups of water in the container, only 8 cups brew. Also, it takes 30-40 min. I ran vinegar through it twice and am getting the same results.
the coils are super heating, and condensation of your water is vanishing faster than it's brewing. It sounds like your coffee pot is ready to go to mr coffee heaven
Aug 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
