Question about Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker
How to re heat coffee after making - Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker
  • 1,140 Answers
Pour it in a cup, then reheat it in a microwave oven. Do not place any metal in a microwave oven.
Posted on Nov 30, 2015
I have a small Gemco coffee pot with no directions. It says "do not use on stovetop",but does not say micro on it either. How do I use it? Pls. help.
I can't answer your question but clearly if there is any metal in the construction of the coffee pot it should not be heated in the microwave oven.
Ceramic coffee pots aren't intended to be heated in order to make the coffee. The coffee is either made in them by adding hot water or made in another utensil and poured into the coffee pot for serving and perhaps kept on a gentle hotplate in the meanwhile. Glass coffee pots are treated in a similar way.
Metal coffee pots and jugs can be used on the stovetop even though it isn't a good idea except for "cowboy coffee" when dry ground coffee is scorched in the jug before pouring on boiling water; steel is best for this.
I have used all manner of glass, ceramic and metal coffee pots and jugs on the stovetop but always using a heat diffuser - two layers of perforated steel with an airspace in between.
A coffee maker is a different thing and must be heated fairly vigorously. I find an old electric percolator is still the superior method of making coffee.
Oct 24, 2016 | Coffee Makers & Espresso Machines
Model 134. Why has it stopped making coffee?
If it is not heating it won't make coffee so check if the hot plate is heating up. If it is heating then I would be looking at the one way valve in the pipe by the element. Be aware that some parts for this model are now obsolete so it may be a good time to send it to the tip.
Feb 02, 2016 | Krups Coffee Makers & Espresso Machines
The machine does not give any water when I make coffee
Hi Irene, The heating coil may be bad. Try to make some coffee and after a minuet take out the carafe and see if its hot.(using caution). If the hotplate is cold after a minuet of use the heating coils are not working. This can happen from no electric, loose connection at the outlet or the coffee maker or a bad heating coil. Hope this helps, Tom
Mar 28, 2015 | Coffee Makers & Espresso Machines
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
The heating light stays on and it wont heat the water
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Apr 15, 2011 | Keurig Elite B40 Coffee Maker
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
My spacemaker coffee maker heats up but does not brew
try a de-scale with 'scalecleen' available from most coffee retailers
Sep 21, 2009 | Coffee Makers & Espresso Machines
Mini brewer shuts off wont heat up wont make coffee Light goes off after cup is placed to catch coffee wont heat or make coffee
thow it on the ground and stom on it. if its not working now theres nothing you can do. Take it to the dump
Jun 28, 2009 | Keurig Ultra B50 1-Cup Coffee Maker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker Logo
46 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
