Hp colour laser jet pro mfp m176n - Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: We have a HP colour laser jet CM2320nf MFP and
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Cheers
Soulvisitor
Posted on Nov 27, 2009
  • 123 Answers
SOURCE: HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
Posted on Jul 14, 2010
  • 8 Answers
SOURCE: Printer Model : HP Laser
indicate that the scanner unit are error.reseat the flexible cable in the scanner unit.
Posted on Nov 23, 2010
  • 3 Answers
SOURCE: hp laser jet m1005 mfp
hi
1. check for driver update
if not resolv
2. Firmware Update
if not
3. the motor of the scaner is damage
Posted on May 30, 2011
  • 5125 Answers
SOURCE: HP Laser Jet CM1312 MFP internal error 0x50
Did the Ox50 error have any additional information with it or happen only with network printing?
Frequently, this error is associated with a font being sent to the printer with the PCL 6 (printer control language). The temporary fix is to turn the printer off and then on (to clear its memory).
Next try going to the Printing preferences by right clicking on the printer in the Printers control panel. (For XP, click Start > Control Panel > Printers and Faxes. In Win7, click Start > Devices and Printers (or Start > Control Panel > Hardware and Sound > View Devices and Printers). Then right click on the LaserJet CM1312 icon and select the Printing Preferences. Go to the Advanced tab and change the Print Data Optimization option from Advanced to Optimize for Text and Vector.
If this doesn't work, uninstall the printer (right click again). Then reinstall the network printer using the PCL 5 universal printer driver. All of the drivers are available here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3558903&prodTypeId=18972&prodSeriesId=3558902&swLang=8&taskId=135&swEnvOID=4063 . The PCL 5 driver is the last one in that section.
If the printer is connected to one computer via a USB connection and then that computer is the printer server for the others, you may need to disconnect USB cable and uninstall both the universal print driver and the regular printer driver. Then reinstall them in the opposite order.
I hope this helps. Please add additional information about the error for more assistance.
(PCL 6 has some issues.)
Posted on Apr 17, 2012
My laser jet pro map m177fw is stuck initializing, and i have tried everything. i have read several other's issues, but mine persists. can you help?
Please review the HP troubleshooting for your printer:
HP Color LaserJet Pro MFP M177fw
If this printer is new, you may need to make sure the toner cartridges are seated and installed correctly.
It appears others have had similar issues and solutions are provided here:
Laserjet Pro MFP M177FW stuck in Initializing
May 16, 2017 | The Office Equipment & Supplies
How to clear memory
the problem with my hp laser jet profession M1217nfw MFP ,receiving faxes
May 25, 2013 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Initializing
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Hp laser jet m1213nf mfp fax storage memory full
hp laser jet professional m1213 nf mfp fax error repot storage full
Aug 11, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
67 people viewed this question
jasbo
jasbo
