Question about Tomtom Tom GO 520, 520T, 720, 720T, 730, 920,...
On start up screen yellow line on bottom - Tomtom Tom GO 520, 520T, 720, 720T, 730, 920,...
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Gv471 fhdtv10a
help my pliss
Feb 07, 2014 | Televison & Video
My screen has a vertical line red-yellow-green from (top to bottom) that stays there. How to fix it?
I do not know any setting that makes a vertical line red-yellow-green from (top to bottom)
If you can find a monitor to connect to and know how to tell the PC to send a signal to it (ie, on a Dell it is Function F8) you can determine if it is your Video card or your screen that has failed. The Video card is part of the Motherboard and very challenging to replace. The LCD screen however is not as expensive and relitively easy to replace. You can watch YouTube videos on how to. A screen can be found at sites like Amazon and EBay.
http://www.amazon.com/Compaq-Presario-CQ70-120US-SUBSTITUTE-REPLACEMENT/dp/B005788D22
http://www.ebay.com/itm/NEW-COMPAQ-PRESARIO-CQ70-120US-LAPTOP-LCD-SCREEN-17-/200514204266
Aug 20, 2011 | HP Compaq Presario CQ70-120US Laptop
I have yellow lines on my toughbook from top to bottom about 1 inch apart all the way across the screen during start up.Can also see the lines faintly in the background all time.
This would be a symptom of a bad screen. The other possibility is that the video cable might be loose. (It's attached to the back of the screen.) it's a rather thin wire; and at time, may work loose. With a toughbook; due to the costs, and expertise required to work on them, make sure you take it to a shop that has experience. OR, you may end up with further problems
Jan 29, 2011 | Panasonic Toughbook CF-73 Notebook
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
Tomtom Tom GO 520, 520T, 720, 720T, 730, 920,... Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
