Question about Precor Exercise & Fitness
Precor treadmill will not turn on - Precor Exercise & Fitness
5 Suggested Answers
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
ercupa190
  • 12223 Answers
SOURCE: Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
Posted on Jul 07, 2012
seanmccann_1
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Posted on Sep 07, 2012
Where can I find a used lift motor for a Precor C966I treadmill? Part # on the motor is 6182A-1705080-01
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am not sure where you can find a used one, but I can find a couple of new options for you. Depending on your machine, there are two different motors available. One is for a 220V machine and the other is for 110V machine. I will post links to both.
MOTOR LIFT ACTUATOR 120V PRECOR TREADMILL PPP000000044257107 SPORTSMITH net
Lift Motor 240V Precor PPP000000044257108 SPORTSMITH net
Dec 22, 2014 | Precor C966i Commercial Treadmill Used
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
God bless your
Jul 06, 2012 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Jul 02, 2012 | Precor 927 Treadmill
Precor 9.27 Control Portion Not Turning On
1) Reset the c.breaker from your house
2) See the c.breaker or blown fuse in your treadmill see the block diagram +c. diagram
3) Try again, and proof.
4) Test the main switch from treadmill, and replace if necessary for OPEn, see the diagram how to do it.
God bless you
Jun 10, 2012 | Precor 9.27 Treadmill
Precor 9.25i treadmill will not turn on at on/off switch. It throws a spark then immediatly turns off
With a few more details I am sure we will be able to work through is issue together and get you back into your exercise program shortly. If you would please give us a call at 1-800-347-4404, one of our technicians will be more than happy to assist you. Please give us a call at 1-800-347-4404 Mon-Fri 6AM-5PM, except Thur 6AM to 3PM, Pacific time.
- Precor Customer Support Team
Feb 28, 2012 | Precor C966i Treadmill C 966i
Where can I buy a replacement walking belt for a Precor 9.21 treadmill?
FitnessRepairParts.com has a walking belt for Precor 9.21 treadmill (it says it is used on four different versions of the 9.21... make sure your specific model number is listed)
Jan 12, 2011 | Precor 9.21 Treadmill
Apr 27, 2009 | Precor C956i Treadmills with HR /...
Exercise & Fitness Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
