Question about Nokia 3410 Cellular Phone
Dead screen, no sign of charging
Always been reliable, suddenly died, have tried removing and replacing battery and SIM card but screen still blank. Have also tried another 3410 charger. Still dead
Fame_Guru
  • 483 Answers
SOURCE: I have Nokia 1100, battery is dead & won't charge
I am sure if you take this to the nokia care they have an easy replacement for the battery.
Thanks
Fame !
Posted on Apr 27, 2009
taran_2005
  • 10515 Answers
SOURCE: the phone won't switch on. I put it on charge, then when I disconnected the charger I found that the phone was dead and won't switch on. I've tried removing and replacing the battery and SIM but it's
There might be 2 reasons for the same.
1. An internal Ic might have been blown. In this case, you need to open the cell. Remove the battery. with the help of a Voltmeter, check the voltage across all IC's. The blown IC would be a bulged or seemd to be swelled.Replace that and the problem would be fixed.
Even if you repair it from outside, it would not hurt your pocket.
2. Motherboard - If this is at fault, you might need to pay around half the amount that you spent on cellphone.It's really hard to fix and more likely demands a replacement. The main disadvantage, you cannot use motherboard of some other cell. It has to be a unique one i.e same model.
Note - I am considering that the battery is fine and fully charged. If not sure, swap the battery.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 25, 2009
rafnix
  • 108 Answers
SOURCE: Unlocked Nokia 5310 doesn't turn on.
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
Posted on Aug 17, 2009
  • 31 Answers
SOURCE: No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Posted on Aug 19, 2009
DeadFfitchy
  • 14 Answers
SOURCE: my e71 went dead suddenly..
hi, my e63 used to do the same thing. i found that if you take off the battery cover and remove the battey then replace it, it should work after 5mins. but sometimes the phone just over heats and switches off.
sorry theres not much help i can offer
from lewis
portsmouth, UK
Posted on Mar 21, 2011
Sony ericsson died and wont switch on
It's likely that you need to reflash the phone software to your phone. You can do this yourself [detailed instructions and files at se-nse.net] or just do it at a phone shop or through an online site like Da Vinci or Wontan.
But something you should try is to remove the battery and take out your SIM / memory card and then let it sit for a bit before you reinsert the battery [withouth SIM / memory card] and restart the phone. Hopefully that'll work, if not then you'll probably have to reflash the phone software. But you could always check by doing a software upgrade using SEUS [Sony Ericsson Update Service offered for free here - http://www.sonyericsson.com/cws/support/...
Jan 12, 2013 | Sony Ericsson T707 Cell Phone
Battery
OK ali,
the red cross on the battery sign means that your battery is "dead".I highly consider replacing it soon, because when your battery dies there is a high chance your screen will go blank when you turn your computer on.
I have looked it up allot, and I have not find a solution to fix this without money, so i had to replace my battery.
Feb 17, 2012 | Computers & Internet
My Nokia N95 8GB suddenly has a problem. It was working until half an hour ago. I took the phone to make a call and saw it had some water underneath the phone. I took it and checked the phone only to see a...
hey sorry about that. but from next time if you see that the phone is wet next moment remove battery and dry the phone never charge or try to use the phone with the battery on. now wat you can do is give the phone for a service. the guy will wash the phone with white petrol and then try starting it. if all the circuits are intact the phone will function back
bye
Oct 03, 2010 | Nokia N95 Cellular Phone
The phone is only 4 months old and it just died. It will not turn on. have charged it.....no signs of life. Taken the battery out and put it back in.....still dead. It was fully charged when it died.
before this thing happen, is there any sign or pop message coming out your phone, "memory full, delete some data"
try to remove your memory card first then try to ope it again
Nov 02, 2009 | Motorola Mobility Rival A455 Cell Phone
My nokia was working fine then its screen went blank and now it is doing nothing....totally dead...help
Hi Friend,
Please find the below mentioned steps and kindly follow the steps,
1.Switch off the mobile.
2.Remove the sim card,battery and memory card.
3.Hold the switch on button for 20 to 30 secs,
4.After that replace the sim card and the battery.
5.Now switch on the mobile,
6.After it has switched on now replace the memory card.
Regards,
Ayyasam
Aug 26, 2009 | Nokia N95 Cellular Phone
My nokia 9300 is dead, i received a phone call and while i was talking i got the low battery message and then it went off, i tried to turn it on again, it is dead, the nokia logo appears for few seconds...
1. let the battery fully discharged without connecting to power supply,
2. remove memory card
3. remove battery
4. remove sim card
5. insert the sim card
6. do not insert the memory card
7. reset the battery
8. connect to power for charging for 24 hours
9. switch on and it will work
inamul@hudaz.com
+91 94350 62943
Jul 13, 2009 | Nokia Cell Phones
New Motorola SLVR is suddenly unresponsive, won't turn on
Try to replace the battery and if the unit is still under warranty advise the store to replace the battery.
Jun 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Samsung u900 limited service
Is the battery fully charged now???
Limited service, is when your not getting any reception, Samsungs usually always get low reception or no reception at all if the battery is low or dying... Remove the sim card, reinsert it into the handset, charge the phone and try again...
If it still doesnt work and the sim card does work in other handsets, its still covered under the Samsung warranty if its less than 12 months old.
May 14, 2009 | Samsung U900 Soul Cellular Phone
N70 - blank screen
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Mar 23, 2008 | Nokia N70 Cellular Phone
Nokia 3410 Cellular Phone Logo
11 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
