Question about Microwave Ovens
Dale Argo privacy lock, on tha cover the hole does not match pin to lock door
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
Replacing door on Whirlpool GH4184XSS1
The top hinge pin has narrower diameter to lock the pin to the door. Just lift the door and relieve the pin and pull it straight up, you may have to jiggle it a little bit to get it loose, no need for heavy force it will just loosens when it is in right position.
Sep 17, 2012 | Whirlpool MH7140XF Microwave Oven
When I turn on my oven for cleaning it shows a f9 problem...could you help me with that
An F9 error code on a General Electric oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Things You'll Need:
  • Ohmmeter or multimeter
  • Phillips screwdriver
#step1
Disconnect power to the oven.
Step 2
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Step 3
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Step 4
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Step 5
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Step 6
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Step 7
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Step 8
Contact a certified repair facility if the source of the F9 code has not been discovered.
Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Do not perform troubleshooting on the oven with the power connected. Personal injury and damage to the oven can result.
Aug 04, 2010 | Microwave Ovens
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
My frigidaire microwave door is sagging and is about to fall off
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Sep 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Popcorn Castastrophy !!!
You would have to remove the top cover and check to see if the main fuse is blown. Usually a 20 amp slo-blow. There are thermal cut out devices, they will reset when the unit cools, so plug it in the next day and see if the clock and power is back up. good luck, Dale
Aug 06, 2009 | Magic Chef Microwave Ovens
Door Removal Sharp Microwave Model R-1611
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
Aug 10, 2007 | Sharp R-1610 Microwave Oven
Replace microwave door
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 On exploded view diagram 4, look at reference part number 4. That is the choke cover. It's held in place with hidden tabs. I've attached a diagram from a Sharp model that will be somewhat similar. Once the choke cover's off, the hardware should be visible. The diagrams do not show the hinged at all. That may mean they're welded to the chassis of the oven. Write back if this does not clear it up.
Mar 12, 2007 | KitchenAid KCMS145J Microwave Oven
Whirlpool Microwave Door
if spring loaded push the pin in firs then hook on spring
Feb 12, 2007 | Whirlpool GH6178XPS Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
