Question about Kenmore 350 Series Water Softener
Hardness set at 100 can not get it back to 40 or 50
Was set at 40 moved up to 100 cannot move back way thank you
5 over 16 as a percent?
5/16 as a percentage is,
0.3125*100-
31.25%
Jan 04, 2017 | Homework
Picture and sound breaks for a split second on Dstv on a regular basis. Signal strengh 85%. Signal quality 100% but it drops to 40% and jumps back to 100%
Digital signals do not have the robust characteristics of the older, analog signals; analogous to the sheet metal of older cars versus the paper thin junk on new cars. The slightest obstruction can be responsible for signal wavering, even a tree leaf or rain in signal path. That is why it is good to get as strong a signal as possible into your set and a good sensitive tuner. Try adding a drop amp into the line but be careful not to provide too much amplification lest you overload the tuner input circuits. Need to experiment. Might also consider moving your antenna to different location and carefully aiming it for strongest signal from your most important stations.
Mar 27, 2016 | Televison & Video
The shoe does not slide or move at all when I pull the shoe release lever down 1/4 turn. Thank you for your attention and response. Noel Thomas
you have to pull the lever down to its fully position, the shoe could be STUCK from not being moved for so long. I would try and tap it back and lube the mechanism and then pull it forward.
Aug 08, 2011 | Milwaukee Tool Milwaukee V28 Sawzall...
Brand new typewriter ML-100 worked fine yesterday. Today, letters are not fully appearing; the ink is only filling in half of each letter printed (just the top portion.) Please help. Thank you!
Hi. There is a lever (left side) to set the thickness of paper. Move that to lower number if you only have 1 paper, move up if you have several pages. Hope this helps.
Feb 03, 2011 | Brother ML-100 Typewriter
Just restarted a 9339-40 ups after moving it to another bldg. And it has no output now. Screen says epo needs reset. Any help?
Most follow the reset procedures to reset from a EPO shutdown. Usually it is a fuse on Powerware that needs to be pushed back in.
May 19, 2010 | Powerware 9330 40 (A40401110031112) UPS...
Hi, I have a TASCO TITAN, 3-9x42, How do I re'paralax it to 35yds
I don't know if your parallax is adj, usually something that comes with the scope, set for around 100 yards. Set up your rifle in sand bags, look at a target at 100 yards, without moving the rifle, move you head left and right , up and down, and see if the cross hairs move off target, No? good, now try it again at 25, 50, 75, etc, where ever it is the least movement is your most accurate range. Some scopes will move 4 to 5 inches off. Not good.
Mar 01, 2010 | Optics
We have a 1999 Toyota Avalon with a problem with the driver's electric seat mechanism. It will move in every position except it will not go back (reverse). Any ideas on how we can fix? Thanks.
This is a switch problem for sure. Try to toggle the switch back and forth very hard and mutiple times. If it moves the you are 100% in need of a switch. The switch is farley easy to replace. Dont buy from dealer. Have a junk yard pull one for you
Jan 06, 2010 | 1996 Toyota Avalon
Ihave a nikon scope that I have sent back 3 times It pareflex, can not get set .
Parallax error is something that could be different in 2 people. What might be ok to some, will be a nightmare to others. Most scopes are set to parallax at 100 yards, but if you set up your rifle where it wont move, vice, box, pads, peek through the scope to a target at 50 yards, move your head back and forth, up and down, do the crosshairs move with you? How about 25 yards, 100 yards? where it doesn't move is where it is set, and where you find the most accuracy in your scope. It is not hard to hold steady, once you get the hang of it, instead of moving your head to set the crosshairs, anchor your rifle to your cheek and shoulder and move your rifle to the target. There are volumes of material written about this stuff. . Hope this helps.
Dec 22, 2009 | Nikon Optics
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
Trying to get the margin move to the left or right beyond where it is set.
Try touching the margin release key, back space to the new location then hold down the code key while pressing the 7 key.
Nov 05, 2008 | Brother ML-100 Typewriter
Kenmore 350 Series Water Softener Logo
66 people viewed this question
Top Kenmore Water Dispensing & Filtration Experts
Bill Boyd
john h
Dennis
Are you a Kenmore Water Dispensing and Filtration Expert? Answer questions, earn points and help others
