Question about GPS
Explorist 500 after firmware update failure the unit does not power on (stay dead like no battery in it) is there something to do
  • 334 Answers
Is your device connected to a pc by USB and doesmthe USB pick it up, will it power on while connected by USB
Posted on Jun 20, 2009
  • seth veloso Jun 20, 2009
    Here are some additional features that can be accessed while the unit is off
    - IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
    - OUT + PWR - to serial port test
    - ESC + PWR - to burn-in process
    - LIGHT + ENTER + RWR - tp uploading of new firmware
    - NAV + PWR - to call Service Function window (see below)
    - NAV + MENU + PWR - to force power off, equal remove batteries.
    - GOTO + OUT + POWER - clear memory and set all settings as default.
    sorry, forget to say to try IN + PWR
    let me know where you are and how you are doing
My Explorist 210 does not connect with any computer. What can I do.
What is happening is your computers are not recognizing your unit. Means you have to update unit via the registered site for updates.
first Perform a hardware reset to return the minor settings of the GPS to the original condition. Press the small "Reset" button on the side of the unit for several seconds until it powers off and powers back on.
If that doesn't solve the problem, then it means you will have to perform a firmware upgrade to put the GPS back in order.
Download and install the Content Manager software available for free from the Magellan support website. Connect your GPS to your computer with a USB cable, and the software will automatically search for firmware updates for your GPS.
Here is support to copy and paste in your browser for Magellan.
http://support.magellangps.com/support/index.php Thanks Mike
Oct 05, 2011 | Magellan eXplorist 210 GPS Receiver
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
Explorist 210 no base map
I solved this problem by gonig to the secret menu by holding the nav + power. I entered the value # 95 in the menu. This will let you format the memory area in the unit then I down loaded the latest firmware update from magellan.com and installed it on the
unit.I had already made a copy of the files on the unit in my hard drive so i copied the files back to my unit so that i did not loose anything important like poi's and geocaches etc...
PS when I did the firmware up date the base map must have been restored.
Jun 27, 2008 | Magellan eXplorist 210 GPS Receiver
Help Explorist 500 jammed (locked up) wont even turn off
To speed things up a bit with frozen Explorists, you can undo the battery cover and pull out the battery then replace and start again. I have had to do this many times.
Jun 10, 2008 | Magellan eXplorist 500 GPS Receiver
No map
Install the firmware again:
Go to: http://www.magellangps.com/support/product.asp?prodid=1114
Or, if this doesn´t work, go to www.magellangps.com, click on "support", click on "legacy products" (left) and click on "eXplorist 210 Europe" (do NOT click on "eXplorist 210 North America")
On this page click under Updates/Upgrades on "version 2.57", and follow the instructions. You will have to register your GPS, register it under a European country.
After you have installed the firmware you will have the basemap and some new windows on the GPS. Good luck and enjoy!
Apr 13, 2008 | Magellan eXplorist 210 GPS Receiver
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
IN + PWR helped to power up my unit.
Feb 24, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500LE with firmware 2.17 (lost)
Have you tried to reset to the factory default? I will be checking some solution for it.
Feb 18, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
GPS Logo
26 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
