Question about Canon Rebel XT / EOS 350D Digital Camera
My canon xsi on camera flash won't pop upeven after i press flash
My canon xsi flash won't pop up even after i press flash button
  • cardiffjr Jun 20, 2009
    no it was working 1hr prior now know matter what it won't pop up
  • Helen Sanford
    Helen Sanford May 11, 2010
    Has it been dropped or been physically damaged in that area? Will it pop up automatically when you are in a low light situation or does it only refuse to work when you manually press the flash button?
  • 71 Answers
I would suggest taking it to a technician to have it repaired. It does not seem like something you should try to fix yourself.
Posted on Jun 20, 2009
I connected an external flash that evidentally wasn't compatable with the camera, now it won't pop up and says thereis an external flash connected even tho there is not.
There is a switch in the hot shoe that detects whether or not an external flash is connected - the pin that operates the switch may be stuck down. Remove the spring piece on top of the hot shoe (I usually use an Exacto blade to loosen it and then slide it to the rear. Then remove the 4 screws and you can see the pin. If it is stuck down, moisten a Q-tip with water and rub it over the pin and blow with canned air to dry. The pin may pop back up. If not, or if the pin is damaged, you will have to remove the top cover and get to it from the bottom.
Jan 21, 2013 | Canon EOS Rebel XSi Digital Camera
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
I have a canon rebel Xsi and the flash will not pop up.
Will it not pop up under ANY circumstances? Try putting the camera in Manual (M) mode, set the shutter speed to 1/200 and the aperture to F5.0, then go in a dim room. Press the button on the camera body with the flash symbol on it. Does it still not come up?
Feb 12, 2011 | Canon EOS Rebel XSi Digital Camera
My Canon Rebel XSi screen will not turn on even though the battery is fully charged.
Does it take pictures? If it does, the display may be off, try pressing the DISP button a few times. If not, the camera may need to be reset, the battery may be faulty, or the camera may need to be serviced.
Feb 26, 2010 | Canon EOS Rebel XSi Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Canon EOS Rebel XSi pop up flash won't "pop down"
Do not Tape it down, If the flash is pooping up all the time take it to a good Camera repair shop to have the catch replaced. At the same Time you may consider getting a full service done.
Dec 26, 2009 | Canon EOS Rebel XSi Digital Camera
Auto flash won't pop up
With the Canon XSi, the flash should automatically pop up in FULL AUTO mode when it thinks it needs to. In modes like Manual Mode, you need to pop it up yourself. There is a button on the front next to the lens that looks like a lightning bolt, that's the flash activator. Try popping your camera into Manual Mode and press that button. If it doesn't work then there might be a problem with the mechanism and needs repairs.
May 24, 2009 | Canon EOS Rebel XSi Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
169 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
