Question about GE Refrigerators
Where is the drain for a tbx24j refrigerator - GE Refrigerators
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
Water leaks from out of refrigerator.
Hello
Check the drain hole. It gets clogged with food particles:
Locate the drain tubes at the rear of the refrigerator
Push a pipe cleaner through the tubes.
Pour a mild solution of soapy water and ammonia down the drain to clean it.
Check the drain pan under the refrigerator, on the left side, by removing the front grill
If the soapy water hasn't drained into it, it is still clogged
Repeat the steps again until the water drains into the pan
Jun 04, 2015 | Refrigerators
There is a hole in the bottom rear of the freezer of my side by side full of water and the over flow is frozen all across the bottom and it leaks onto the floor
How To Clear the Drain Tube Before clearing the drain tube, unplug the refrigerator or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2011 | Refrigerators
Our refrigerator is cooling and our freezer is freezing, but there is a leak coming from the freezer area that is dripping down into the refrigerator that just keeps getting worse and worse. Appears that...
Hi maabjcraft,
Have you tried clearing the drain tube?
Hope it helps.
Thank you for using FixYa.
May 18, 2011 | GE GTS22WCP Top Freezer Refrigerator
Im getting water under the vegetable drawer inside my LG refrigerator..what can i do?
Hi boris_sal495,
There are two things that you can check if you are getting water under the vegetable drawer. Kindly refer on the details below:
Reminder:Before doing any checking or repair unplug the refrigerator from power and remember your safety.
1. Clear the Drain Tube - Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
2. Leveling a Refrigerator - It is important for the refrigerator to be level.Check that the refrigerator is level from side to side.If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An icemaker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then tighten the screws.
Hope it helps.
Thank you for using Fixya.
May 03, 2011 | LG LRTBC1825T Top Freezer Refrigerator
Another refrigerator with same problem
Pull the refrigerator away from the wall.
Inspect the drain line and drain pan.
The drain line comes down the back of the box and into the drain pan on top of the compressor.
The drain line may have a crack in it or may be missing the pan.
The drain pan may have a hole in it.
Jan 26, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is accumulating in the bottom freezer and freezing...I continually have to chisel it out. We have tried defrosting it but have the same problem a few days later.
Hi.This will normally be caused by a clogged drainage hose or plug. There is a drain leading out of the freezer and another from the refrigerator. In top freezer models, the freezer may drain the water onto the back wall. It actually runs down the wall to the refrigerator floor drain. In other cases, there may be a drain tube leading out the freezer. The refrigerator drain is either located on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel. In side-by-side models, the freezer and refrigerator will probably each have an outlet to the drain pan under the appliance.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Dec 09, 2009 | Kenmore Refrigerators
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
Estate TT21AKXKQ Refrigerator Leak
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 17, 2008 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
