Question about Inverter Sew Eurodrive Movitrac 31c055-503-4-00 Ac
Inverter not ready
Inverter is giving a 0 code saying inverternot ready
WHIRLPOOL MICROWAVE GIVING F-7 CODE
hello sir
you are right magnetron is fully interrupted....... but tell me  !. do you want to repair machine( 4 sec problem) 2. do you want to buy inverter , magnetron  please tell i am ready to help you sir
I believe that is a microcomputer board failure. You will have to replace this board. Website below.
I have gotten parts from "repairclinic" on line and they worked fine. I saved $600 on the last repair of an oven. Good luck.
or sir you can find and fix each and every type of code error
http://www.applianceaid.com/micro_faultcodes.html#WLP
Oct 18, 2008 | Whirlpool MH6140XK Microwave Oven
MY microwave is giving me an error code F7 - call for service
This is all i could find on this error, Its alot to check. Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly
Jun 23, 2011 | Whirlpool GMH5205XVS Microwave Oven
I need free Information for my prob for toshiba estudio 200L. gives code F120.
Your HDD is having issues. First try to rebuild the databases by holding 0 and 8 while turning on the copier, when the machine comes ready key in 684 then reboot the machine. If this doesn't work you can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 15, 2011 | Toshiba Office Equipment & Supplies
Hello sir, I have a prob toshiba studio 200L. gives Code F120. how I solve the prob, pls halp me..THANKS. My asar596@yahoo.com
Says searching but never connects. the yba-10 blinks boes not connect
On RXV3900 using the remote there is a submenu for YBA-10WH (submenu shows Trim, Pair, Connect). Selecting Pair causes the YBA-10WH blue light to flash. Once iPod has Bluetooth set to ON it then displays a box showing "YBA-10WH not connected".
First attempt to connect requires tapping this box which produces the invitation to enter a 4 digit pass code. I had several attempts using pass code for my iPhone - all failed giving message "Make sure yba-10 yamaha is turned on in range and ready to pair". I finally tried keying in a pass code 0 0 0 0 and it paired!
Once turned off subsequent attempts to enable Bluetooth were much easier requiring tapping of the box but not requiring entry of any pass code.
Turn off seems to work easiest by using the remote to select the "Connect" option on the submenu and then selecting Enter on the remote - this caues display of "Disconnected" message on the RXV3900 screen.
Now works fine!
Apr 10, 2011 | Yamaha YBA-10WH Bluetooth Wireless Audio...
Why does my dr3624 only put out 98 vac, its rated at 120 vac? i'm off grid and my batteries are new 24 volt
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
Oct 03, 2010 | Xantrex Technology DR3624 Inverter/Charger
Error code f120
Aug 20, 2010 | Toshiba E-STUDIO 450 Copier
2001 pt cruiser codes po 605 and po 700
Diagnostic trouble code P0605 indicates internal Transmission Controller fault. Needs to be replaced
Jan 07, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Inverter Sew Eurodrive Movitrac 31c055-503-4-00 Ac Logo
133 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Clint Millett
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
