HP Support Communityhttps://h30434.www3.hp.com > td-p
May 14, 2015 - Use that code to go into the BIOS. Disable all passwords that are enabled. If asked for the CURRENT password use that code. If asked for NEW ...
h30434.www3.hp.com > Laptop & Notebook > Notebook OS Aug 6, 2011 - 10 posts
Windows 7, Pavilion dv6 Laptop Log in Error ... I am having the identical problem ... after the 08-05-2011 Digitial Fingerprint software update to ...
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2.
Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to
the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook. The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4.
Turn the computer display-side up and open it as far as
possible. Insert a guitar
pick or small flat screwdriver between the keyboard cover and case and slowly move along the
side.
5. Lift the keyboard cover. Be careful, it's
still connected to the motherboard. Release the zero insertion force
(ZIF) connector and disconnect
the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift
the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the
keyboard back to disengage the tabs on the front edge of the keyboard
from the top cover and rest it on the display.
8.
Release the ZIF connector to which the keyboard cable is attached and
disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below: http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
If the screens are 6 individual screens you have a software problem
Go on any one of the screens and hit the Right mouse/touch-pad button to get into screen software
Take each of the 6 parts and put them on ebay for sale. This way you might make enough money to buy a new laptop. Either that or be more descriptive in stating your problem.
have the same problem. if updating the graphics driver doesnt work then it probably is the same as my problem. HP service center said it's the graphics card or video card but since the video card is embedded in the motherboard, then you will have to replace the motherboard.
