Question about Garden
Husqvarna cth210xp drive belt squeals
Have husqvarna model 93605500/a25h54 need diagram for drive belt
If you go to www.Husqvarna.com/us you can put in your model number and get an IPL or owner's manual this will show you how the belt fits on the tractor.
Sep 19, 2014 | Husqvarna Garden
2000 montero sport: There's a loud squealing noise coming from the engine. What could be wrong?
Squealing is most common with loose or worn belts, I would start by replacing the drive belt on the front of the motor and go from there, Its easier to troubleshoot a squealing motor if you know that the belt or belts are good.
Oct 20, 2012 | 2000 Mitsubishi Montero Sport
Squealing noise (LOUD)
You need to check the pulley alignment of all the pulleys, they should all be in a perfectly straight line, otherwise the belt will squeal
Aug 24, 2017 | 1988 Jaguar XJ6
Hi I have the YTH2348, the problem i'm having is i'm getting a bearing sounding squeal when i have the blade clutch engaged. I noticed before it starts to squeal I'll hear a like loud click and...
if its an elect pto then it sounds like its in the workings of the pto pully
also if its a manual lever that you move to engage the belt, it could be the pully that tightens up the belt and turns the blades, most of the pullies are greaseless and prettymuch throw away
Jul 25, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How can I find out if the mower belt is wore out or to loose or when to replace the belt and is it hard to replace the belt
hi there
here is web site for owners manual for belt replacement proceedure from the owners manual - you can download on
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=yth24v48ls&types=O,I
then from hre you can download a parts listing for machine as well
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532432802.pdf
here is web site so you can get a new deck belt
sounds like if the belt is shiney , feels quite soft , and signs of burn spots in it ,it will need replacing
particulary if you notice when the grass cutting load comes on the blades seem to slow down then speed up -and sounds like its squealing ? it indicates belt slip
check it out its a good site
your local shop should be able to source belt
its pt number 574-84-56-02
cheers hope it helps pauly 46
Apr 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Squeals on startup for about 1 minute then goes
Remove motor shroud and inspect the drive belt VF is imfamous for squealing drive belts better to call them and order a new belt here is their # 1-800-335 4348 Vision is now under there parent corp. name Johnson
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
My 97 blazer squealing has been driving us crazy with a
Could it be the pulley on the AC that's squealing? Use a mechanic's stethoscope to locate the squeal. If it is the AC, you can get a belt that is shorter, and bypass the pump, since it doesn't work anyway. Try some belt dressing first. When the engine is running, just spray it on the inside of the belt.
Jan 24, 2010 | Chevrolet Blazer Cars & Trucks
Need belt diagram!
I found these 3000GT/Dodge Stealth DOHC Serpentine belt diagrams on the link below...
http://www.stealth316.com/2-ac-compressor.htm
If you are re-using the drive belt, be sure to install it in the same orientation as it had before removal (same side facing the wheel well). Insert the belt from above. Turn it "sideways" to fit it in between the alternator pulley and the AC pipe. Correctly tension the drive belt using its tensioner pulley. Before installing the plastic covers and wheel, temporarily install the IC pipes and battery negative cable and start the engine to check the belt operation. If the belt squeals it is either misaligned or too loose. I found that my old belt squealed when installed "backwards" from how it was removed. It did not squeal when installed in the same orientation. If you have messed with both drive belts, spray a little water on one belt at a time to see which is squealing. A misalligned belt will stop squealing for a very short time after water is sprayed on it, but the squealing quickly comes back louder than before. If the belt is loose, the squealing will immediately get louder. Also note that there is just a little play in how the alternator bolts in. If misalignment is a problem, loosen all four bracket mounting bolts (this may require again removing an IC pipe), reposition the alternator, and tighten the bolts to see if this helps. Do not tighten the belt too much because this can lead to shaft bearing failure over time.
Here are some links concerning drive belt adjustment.
http://www.gates.com/brochure.cfm?brochure=1026
http://www.ridgeautoparts.com/tips/the_charging_system1_2.htm
http://www.utfleets.com/library/features/accessory_drive_belts.htm
Your Pal,
Annulusgear
Apr 12, 2009 | 1991 Dodge Stealth
Husqvarna yth2443t little or no movement
make sure the trans. linkage can operate freely. Had the same problem,it was just a build up of grass and dirt.
Apr 12, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
