Question about DeLonghi Kitchen Appliances - Others
DeLonghi toaster sparked and smoked.
My hot cross bun caused a flash and smoke and now that side of the toaster wont work. Can I fix it? Thanks
  • 22 Answers
No. The bun is no longer edible.
Posted on Nov 07, 2014
3 Suggested Answers
SOURCE: toaster smoked
where can spellcheck.gifi get the maneal to use it
Posted on Feb 02, 2008
SOURCE: VCT-10 model toaster
I think if you replace the bushings (#2150150) that will keep the chains from getting stuck on the sprockets. I have to do this 1 or 2 times a year.
Posted on Feb 10, 2009
One side of our 4 slice toaster won't work.
If you pull it apart and have a close look you will notice one of your Tungsten bars is broken. This causes an "open circuit" situation. Hence one side not working, Easiest and probably cheaper to buy a new toaster, you can buy the fillament material, however the terminations may prove difficult
Oct 21, 2013 | Delonghi DC514T 14-Cup Programmable Coffee...
Slight smoking, smells like melted plastic or paint
I would have said the new is smelling , but don't run the risk here, take it back and get another, unless you want to call there help desk.
Jan 18, 2013 | Kitchen Appliances - Others
Why is water leaking out from the side tank
It is also smoking from the top of the warming plate and get's very hot. The water seems to be leaking from the top down to the side of the water tank.
Is it worth fixing? How much would I have to spend to have it fixed? Maybe I should just by a new one. My machine is only 4 year.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
I put a starter on my car it wouldnt crank it tried to but wont it was making a dragging sound then started clicking and the battery went dead then i tried it again and a spark and smoke came from the...
Sounds like a wiring issue. You may have crossed the wires going to the solenoid. This would account for both the sparks and smoke. Be careful, you can blow up a battery if you have wires reversed. Double check the battery cables to ensure they too are not crossed.
Oct 29, 2011 | 1999 Ford Crown Victoria
My 98 is shaking at the engine and smoking the fluids are up could it be the spark plug wires and the spark plugs
HI,
Spark plugs or wires will cause engine shaking, but not SMOKING.
I would identify the source of the SMOKE first. If it is a fuel leak the smoke may turn to fire. This is not meant to scare you yet with out seeing it I know a fuel leak will cause a engine to "shake" and create smoke as the fuel touches a hot exhaust manifold.
Feb 26, 2010 | 1998 Oldsmobile Intrigue
My car is smokeing under the hood what would be the problem
SMOKING UNDER HOOD CAN BE CAUSED BY MANY THINGS.BUSTED OR LEAKING RADIATOR HOSE.POWER STEERING HIGH PRESSURE HOSE RUPTURE GET FLUID ALL OVER HOT EXHAUST MANIFOLD CAUSING SMOKING.LEAKING VALVE COVER GASKETS ALLOW OIL TO LEAK DOWN SIDE HEAD TO HOT EXHAUST MANIFOLD CAUSING SMOKING.ELECTRICAL SHORT CAUSE SMOKE.
Oct 06, 2009 | 2000 Nissan Maxima
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Bunning smell.
Is it an electrical smell or a rubber type smell. If there is no smoke, it could be that the belt is slipping and causing a smell. If it is the motor, usually it would smoke, or at least quit running and making strange noises.
Jun 16, 2008 | Vacuums
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
Kitchen Appliances - Others Logo
148 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
