Question about Bernina Sewing Machines
Bernina foot controller broken - Bernina Sewing Machines
  • Peter Jones
    Peter Jones Feb 03, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Scholar:
  • 74 Answers
You really need to say more about what is broken. Does any part of it work? Which machine is it for?
Posted on Feb 03, 2015
5 Suggested Answers
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
  • 22 Answers
SOURCE: Bernina 900 ''Electronic Power'' foot control needs repair
You will need to go a bernina dealer to by those pins the part number is 325 355 031 and each pin cost around $4.00 each
Posted on May 03, 2010
  • 166 Answers
SOURCE: Bernina 930 foot control cord
Not easily - the plug is molded-on so it's best to get a complete new cord - they're still available.
Posted on Mar 12, 2012
  • 643 Answers
SOURCE: I need a replacement foot control for bernina 900
Check out the following link he should be able to help
http://www.whitesewingcenter.com/berninaparts.php
Posted on Feb 27, 2013
My Bernina "Record" of 1972 suddenly stitches away without foot pedal command, infact same with pedal unplugged Only way to stop is cut AC power
Something with in your machine seems to be shorting out. Since it is many years old I suspect you have wires that the insuation is rotten and making a short. I have seen this before. Should get it repaired if it's worth it. You could be shocked or hurt.
Oct 21, 2016 | Bernina Sewing Machines
Bernina machine starts sewing anfmten stops or doesn't start at all.
Be sure that you regularly clean and oil your Bernina. If not oiled regularly, the old oil turns to varnish and actually freezes the parts. Some people believe something is wrong with the motor or foot control, when really it just needs some TLC to keep it running smoothly.
May be one of several issues--depends on the model Bernina. Could be a problem with the foot control. I had to replace a carbon brush in the foot control of my 930. (A new foot control could cost over $160!)
Repair Bernina Type 290 Foot Control Pedal
http://sewing.patternreview.com/SewingDiscussions/topic/92721
https://tv-sewingcenter.com/bernina/bernina-830-fire-hazard
Sewing Foot Control Replacement
Or some machines (mostly older models, ie 830 Records) have carbon brushes on the motor that wear with age. Once they've worn down, they no longer make constant contact giving you the "intermittent" issue. I've replaced carbon brushes on some older Berninas--usually found somewhere around the motor (look for a screw or knob on the motor). You can buy replacements a lot of places. I've purchased them on eBay.
Sewng machine motor housing
How to fix replace Bernina Record 830 sewing machine motor capacitor...
Where are the carbon brushes located on Bernina sewing machine located It...
Carbon Brush Bernina 324250080 (make sure it will fit your model)
http://artisanssquare.com/sg/index.php?topic=3040.30;wap2
Oct 01, 2016 | Bernina Sewing Machines
Bernina 1006 foot peddle does nothing
Not sure. It could be something to do with the foot control, power cord, or the motor. Does the light come on? If so, it's probably not the power cord. If you have access to another foot control and power cord, that is an easy way to test. Otherwise, might be best to take it to a Bernina technician.
Bernina 1006 Parts
Bernina Foot Control Power Cord for 1000 800 Series
http://www.drdanessmh.com/berninaftc.html
Apr 03, 2016 | Bernina Sewing Machines
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Feb 02, 2012 | Bernina Sewing Machines
Do I have to buy a Bernina foot in order for it to work on my Bernina Virtuosa 160
Yes. Bernina feet aren't interchangeable with other machines and non-Bernina feet won't fit a Bernina. Sorry.
Robbie
Aug 02, 2010 | Bernina Virtuosa 160
Apr 22, 2010 | Bernina Sewing Machines
BerninaMatic 910 Electronic machine. The foot control has broken
Bernina foot controls cost a fortune, have a look on ebay you find someone selling spares, other than that it will mean going to a Bernina dealer
Nov 03, 2009 | Bernina Sewing Machines
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
