Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
How do I get the head off of the trimmer?
How do I get the trimmer head off of the body.
  • 1,041 Answers
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
Replace trimmer head
Most trimmer heads unscrew clockwise. Watch the video which shows how to remove most trimmer heads.
How to Replace Trimmer Head
May 30, 2014 | Tanaka Trimmers Tbc-230sf String Line...
I have a Toro 8" cordless trimmer. I hit a big weed and the trimmer stopped and will not restart. Help.
check for bits of the weed wrapped around the head and the motor body that is jamming the head and stopping it from spinning. It will not take much to stop it from working
Aug 11, 2013 | Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Jan 16, 2011 | Conair GMT 170 CS Beard Trimmer
How do you get the head off the troy bilt string cutter? I'm try
If by "tearing it up" you mean that little retaining ring inside the main body of the head, that's correct. It must be destroyed to remove the main body.
Very very few of these trimmers can use a different mowing head without suffering damage to the gearbox, driveshaft or centrifugal clutch. (These are VERY LIGHT DUTY trimmers.)
As for the advice you seek:
"Don't run any other head on this unit with expectations of the trimmer holding up."
Troy-Bilt offers other attachments for this engine to use in performing other types of jobs.
At my shop we see a huge percentage of these units with failed drive shafts and gearboxes.
Probably not what you wanted to hear, but it's better than telling you the wrong thing and then you end up being unsatisfied with the solution I offered. I truly wish you good luck.
Hope this helps,
Dolf-
Oct 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
475 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
