Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I HAVE A PHILIPS 9P5034C102 CHASSIS PTV835, THE CONVERGENCI IS OUT BUT STK IS OK iDONT HAVE -32V CAN HELP ME PLEASE
    Brigadier General:
  • 8,619 Answers
Hi
When you say Convergence ICs are out I believe you are talking about the amplifier chips that send signals to the projectors are shot.
The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
PHILIPS MAGNAVOX Picture Color Off
hi i hope i can help you?. please check the arial connection. may i please ask you if you open up . go to where the red light is and check for any adjusters.if you find turn down the red top tip if you use a mirror and place in front of the tv and tha t way you will see what is hapining.
May 08, 2009 | Philips Televison & Video
I need a owners manual for my TV.
you can get one for free at the following link just let them know your model number in a emmail by clicking the contact link on the lower left side of their page.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Televison & Video
NO PICTURE ON MY TV BUT I DO HAVE SOUND.
Check all your cables, make sure CRT boards are tight. Make sure you put the black ground wires back on the tubes. Also make sure that no fluid has spilled on the circuit boards.
Mar 27, 2009 | Philips Televison & Video
Can You PLEASE help me
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Jan 22, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
DPTV335
Ed did you change the yokes when you put the DPTV series CRT into the PTV chassis? If not its most likely the vertical output or the Horizontal output that got destroyed. If you changed the yoke its most likely the HV generator.
On the DPTV chassis that should shutdown the vertical deflection which would leave audio working worse case scenario would also be the HV generator and Horizontal output.
Oct 20, 2008 | Philips 60PP9202 60" Rear Projection...
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Regarding service manual for philips magnavox
You can also get a Factory Service manuals from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Feb 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
