How much was avon liiv chime clock - Audio Players & Recorders
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
My sterling and Noble westminster chime clock is not chiming. I have brand new batteries installed but still no chime
A handsome clock in solid red oak. The face is off white with a convex lens and a bright brass-toned bezel. The Westminster chime is pleasant sounding while counting the hours.
Runs on 4 AA batteries; two to manage the clock and two for the chime. The external speaker is located at the top of the clock for a clear, unimpeded sound. A button on the chiming unit allows you to control the striking of the hours.
You will see above that one set of batteries does the chime. Make sure they are good and inserted with correct polarity.
As mentioned, look for a button switch to turn the chimes off It is a feature so you can turn the chimes off when you go to bed.
Sep 14, 2015 | Home
My Gazo GF Clock won't chime on hour at all
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
Dec 17, 2014 | Home
My clock chimes the correct amount of chimes on all hours except 7. At 7 it chimes 5 times
In a quartz movement clock, with a problem like this, the chime box (or whole movement) will need to be replaced. Timesavers.con carries a large selection of chiming quarts movements.
Jan 12, 2014 | Howard Miller Greer Chiming Quartz Wall...
Chimes do not work
Check for loose wires between the clock Movement and the chime box. If those are good (and the batteries have good solid connection-not lose) you probably need to replace the chime control box or the whole movement.
Timesavers.com carries replacements.
Mechanical clocks, while more in cost, will live a much longer life with proper care than battery clocks. Plus, an actual chime (not noise through a speaker) is much more pleasing to the ears.
Jan 11, 2014 | Seiko Mantel Clock
How to reset wesrminister wall chime clock
If this is a mechanical clock, make sure the chime lever is set on. If quartz there is a reset button to forward the chime advance until it matches the hands.
Mar 19, 2013 | Seiko Mantel Clock
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
I have a Strausbourg chime mantel clock. It chime 2 minutes late every 1/4 hour, how do i fix this. Rae
I lost directions to my clock, it takes two double a batteries for the chime but i dont know how to set it.
thanks
Dec 06, 2009 | Seiko Mantel Clock
18 people viewed this question
 Grubhead
Grubhead
