Question about HP CP3525N Color LaserJet Printer
When i sand a test page the printer show an error 59.f0 what can i do
    Scholar:
  • 121 Answers
Pull the transfer unit out, and turn the white gear on the side. Not the one that turns the transfer belt--the one that causes the belt to push up against the toner cartridges. If the gear turns somewhat freely (it's not stuck), then reseat the transfer unit and see if the error goes away.
More comprehensive troubleshooting guide is here:
http://www.partsondemand.co.nz/uploads/97806/files/Feb_14_59.F0_error_Tech_Talk.pdf
But if it passes all the "checks" and you still have the error, check this out:
http://cincinnatiprinterrepair.com/hp-cp3525-59-f0
Posted on Aug 12, 2014
5 Suggested Answers
APremkumar
  • 564 Answers
SOURCE: hp 3325 printer printing test page and not printing other pages
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Apr 06, 2009
SOURCE: error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Posted on Jun 14, 2009
  • 40 Answers
SOURCE: after removing a test page the printer HP5550 shows 59.C0
check RAM
Posted on Aug 01, 2009
SOURCE: HP Laserjet CP2025
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
Posted on Jul 22, 2010
My printer is showing error 59.0F Hp laserjet cp 2025
see some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
Apr 28, 2016 | Office Equipment & Supplies
I have an printer Laser jet HP P2055d the problem is 59.f0 error i need every body help thank you
This is a hardware problem, time for a new printer, below are the causes for this error:
  1. Transfer belt is locked up and cannot rotate.
  2. Sensor SR17 (primary transfer-roller-disengagement) is bad.
  3. Damaged or broken fuser drive gear. Typically, a grinding or clicking noise will be heard during boot up.
Mar 15, 2016 | HP LaserJet P2050 P2055DN Laser Printer -...
Hp cm3530 error 59.F0
chance the sensors chance the motor on the fuser and big gearbox chance the transfer belt chance the main board the err 59f0 on a hp cm3530fs ,what can be the cause !!!!
Mar 19, 2013 | HP Laserjet Cp2025n Printer
Laserjet cp3525 error 59.f0
If it helps, I solved the error 59.F0 blowing on the sensors that are on the outer side (right door) under the edge of the transfer belt. You must remove the fuser and transfer. To locate the place to blow, craft and close the door stations toners, we see a long plastic slide guide in the machine with the door movement. Must blow into the small holes that are filled with dust with compressed dry air.
Good luck.
Jan 09, 2012 | HP CP3525N Color LaserJet Printer
HP Color LaserJet CP352dn 59.fo error
59.F0 ERROR
The primary transfer-alienation motor has experienced an error.
1. Check to ensure the ITB is installed correctly.
2. Run a sensor test to verify that the primary transfer disengagement roller is functioning. If not replace the sensor (SR17).
3. Run the primary transfer drive test in actuator drive mode. If not functioning replace the ITB (Intermediate transfer belt).
Jul 27, 2011 | HP Laserjet Cp2025n Printer
On switching my Hp laseret 3800, after initializing, it will show red light and said "59.f0 error switch off and on to continue"
check on the optional paper tray if there is still a piece of orange tape , remove all orange tape from the printer , is it the first installation?
May 27, 2011 | Office Equipment & Supplies
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
Mar 27, 2009 | HP Laserjet Cp2025n Printer
Error 59
Error 59 normally refurrs to the fuser unit replace and test.
Thanks J
Nov 04, 2006 | HP LaserJet 3600dn Printer
HP CP3525N Color LaserJet Printer Logo
294 people viewed this question
Seeker5211
Seeker5211
