Question about Canon EOS 1100D Rebel T3 Body Only Digital Camera
My camera says "Cards write protect switch is set to lock" what should i do to unlock
I reformat my sd card in throughcomputer,because the sd card reply need to reformat, when i try to insert it again to my camera, the camera says " cards write protect switch is set to lock
    Sergeant:
  • Canon Expert
  • 488 Answers
There is a very small lock switch on the SD card make sure it is not on lock.
Posted on Sep 02, 2016
SOURCE: "No Memory Card" error.
PLEASE can anyone help. I have the same problem too and I'm about to go on vacation. I need this camera to work. Please help.
Posted on Aug 21, 2008
  • 17 Answers
SOURCE: Card Locked
try formatting in the menu.WARNING this WILL delete all images from camera. if it will not let you camera needs service
Posted on Jun 14, 2009
Crankstart
  • 696 Answers
SOURCE: SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Posted on Sep 03, 2009
Testimonial: "Scotch tape worked just lovely!!! Thank you!"
ColdTattoo
  • 219 Answers
SOURCE: When in insert my SD Compactflash cards 128MB,
Same problem but with a different camera. Turns out, these cameras are very... may I emphasize very... picky as to which cards to use. Try other off-brands and you'll be surprised as to what it takes.
Posted on Sep 22, 2009
t00nz
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
Unlock memory cardcard write prot
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 08, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Memory cards work, t2i gives Card Write Protected message. Took battery out, reset settings to original, tried tape over card's protect switch
Oct 29, 2013 | Canon EOS 550D Rebel T2i Digital Camera
Release Write Protection
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 19, 2012 | Cameras
I cant take photos anymore and the LCD screen says CARD'S WRITE PROTECT SWITCH IS SET TO LOCK.How can i solve this problem?
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
If this doesn't do it, try another card.
Dec 28, 2011 | Cameras
My Canon EOS camera was working fine. Now that I want to take pictures it say card write protection. How can I fix the came so I can take pictures?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Wat is write protect
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card, allowing the camera (or any other device) to write to the card.
Mar 18, 2011 | GE Cameras
I want to reformat my sd card using my computer but theres an error saying my card is ROM
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 18, 2011 | Cameras
My cammera is locked i dont know how and why i try to take picture it says THE CARD IS LOCKED i turn it on it says the same i pretty much cant do anything, how can i unlock it or fix it????
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 08, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Memory card locked. Will this camera support SDHC cards or just SD cards
The A540 uses SD cards, not SDHC cards.
Nov 01, 2010 | Canon PowerShot A540 Digital Camera
How to delete a protected image from SD card
If the card is locked, unlock it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If the image is locked, cancel its protection. While viewing the image, press FUNC/SET to toggle the protection.
Sep 11, 2010 | Canon PowerShot A610 Digital Camera
Canon EOS 1100D Rebel T3 Body Only Digital Camera Logo
164 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
