Question about Dell 926 All-In-One InkJet Printer
Cover Open issues
My printer screen says Cover open but the cover is closed. Now the printer won't work
    Problem Solver:
  • 19 Answers
There is a molded-in blade on the rear middle right side of the cart cover. This hits a microswitch just below it when the cover is open. The little plastic lever of this switch just snaps on and can snap off and jam or something else can jam this switch down. This makes the printer think the cover is open.
Open the cover and look to the top, far rear and to the right for this triangle blade sticking down. The switch is just below.
Posted on Jul 03, 2009
  • 85 Answers
U will have to find out a little Button, which is pressed by the cover when u close it,,, now find out the little button and press manually and then try to print .... it will work properly....
take care
shafky
Posted on Jun 20, 2009
HP P4014n LaserJet Printer Close top cover won't close
the most common problem that causes the top cover not to close is the toner cartridge not being seated. Pull it out and reseat it.
Why did you open the cover in the 1st place. If it was to install a new cartridge, try putting the old one back in. If it works, the replacement has a problem.
If the cover doesn't close with the toner cartridge removed, then there probably is a linkage problem. Something may be broken, like the "print cartridge drive arm".
Go out to www.hp.com.
Oct 10, 2011 | HP LaserJet P4014n Printer
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_472b46f833fc3109
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
Open the top cover and insert a toner cartridge. message shows when i try to print but top cover already closed properly
check on the left hand side of where the top cover opens , in the inside there is a clip along with a senor
check that it si not stuck . if that doesn't work, open the top cover hold in the cancel button or the bigger play button ( differs printer to printer ) or both for approx 10 - 20 seconds , you will see all the lights flash remove the toner , re-insert the toner & close the top cover . This will reset the drum unit & the printer status. Alternativly switch the printer off ( with top cover closed ) hold in one or both buttons and turn it on for approx 10 - 20 seconds again , you will again see all the lights flash, Your printer will reset its status And clear its page count .
also try open the back cover close the front then the back , press cancel or play button twice there after.
( this is a common diagnostic procedure with small laser printers )\
Please post back if this doent solve the issue
Thanx
May 27, 2011 | Canon LASER SHOT LBP-2900 Printer
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
I have Canon MP520, the screen has backlighting but no info, what is the fix please
Turn off printer.
Close readout cover.
Unplug printer. Wait at least 5 minutes.
Plug back in printer
Open readout cover
Turn printer on
This will reset the printer
If this does not work, try turn off printer
Open and close the readout cover slowly couple of times
Turn printer back on
If still does not work, try a different outlet
the voltage could be low.
Dec 26, 2010 | Canon PIXMA MP520 InkJet Printer
Printer keep saying cover is open and cant find
====.> continued from an earlier answer that seemed to close up too soon, before I finished typing my response.
... and the cover appears to the printer to be open. If you can clean this photo-ectric sensror, it will tell the printer that the cover is actually closed, as it should, and the printer will return to printing as it should do.
Clean all photoelectronic sensors, to ensure that they are all going to respond as they should, and your printer will then work fine.
-a.
Dec 06, 2009 | Dell Office Equipment & Supplies
Printer cover
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Back Cover Open
I've been researching this problem. It seems to be a common issue with this MFC. Apparently it's not only a known issue, but Brother has no fix for it outside of replacement.
May 09, 2007 | Brother MFC-7820N Laser Printer
Dell 926 All-In-One InkJet Printer Logo
170 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
