Question about Brother P-Touch 1950 Label Printer
Pt1950 I'd like to use the PT1950 on Ubuntu 12.04. Is there a recommended way to do this?
How do I get ant virus programme for Ubuntu
There are many antivirus programmes available for Linux or Ubuntu
However I will recommend using Avast. please use the following link to download the installation file and also use the steps show in the screenshots and reply back if you need assistance.
http://www.ubuntugeek.com/avast-antivirus-for-ubuntu-desktop.html
Feb 22, 2012 | Canonical Ltd. Ubuntu
Will ubuntu work with hard drives that have advanced format ?
Advanced Format drives are supported by linux distributions running kernel 2.6.31 or higher, though for best results 2.6.34 is recommended.
Ubuntu has shipped with support for advanced format drives since Ubuntu 9.10, so if you are setting up a new system with the latest Ubuntu 11.04, you shouldn't experience any problems.
For more information, you may want to have a read of Western Digital's customer service article about support for advanced format drives in Linux; http://wdc.custhelp.com/app/answers/detail/a_id/5655
You may also want to review the list of kernels included in various Ubuntu distributions in the wikipedia article at http://en.wikipedia.org/wiki/List_of_Ubuntu_releases#Version_history_of_common_programs
If you are considering upgrading an existing system, you can find out what kernel you are running by enteringuname -rat the command prompt.
Oct 10, 2011 | Canonical Ltd. Ubuntu
I need pointer to tool/software preferably recommended by Toshiba thru which I can check health of my Hard Disk - MK4021GAS.
I recommend going to ubuntu.com and downloading the latest version of Ubuntu. Burn it to a CD or USB Drive, then boot off of it. Once you get into the Live mode (Try without installing), open Disk Utility, and you can run diagnostics on and check the health of your drives.
Jun 28, 2011 | Toshiba MK 4021GAS (MK4021GAS) 40 GB Hard...
I installed ubuntu 9.04 version in toshiba satelite640 model in that inter net was not connecting to install my ubuntu files please suggest me to clear problem
Are you trying to connect wirelessly? or via ethernet? It is fully possible that your hardware does not have support with the version of Ubuntu you are using. I recommend getting the latest revision on a cd or dvd and installing from there.
Sep 25, 2010 | Computers & Internet
Can I Install Linux via USB Flash Disk for mu Panasonic CF-18, plz help me
Yes, you can do it. I recommend you install Ubuntu Linux. To do this you need the following: 1. Download the distribution from the site www.ubuntu.com/desktop/get-ubuntu/download 2. In paragraph 2 "Burn your CD or create a USB drive" on this page, select "I would like to create a: USB stick " 3. Follow these instructions
May 30, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
I've got a working internet connection through the DGN2000 from a Vista laptop, and an Ubuntu PC. The Ubuntu PC uses a D-Link USB Wireless dongle. When I try to use the Netgear WN111V2 dongle, I cannot...
ubuntu's wireless support is flakey, but it improved with Ubuntu 9.04
I had a similar problem in Ubuntu 8.10 with Netgear WNDA3100. Recommend that you install Ubuntu 9.04 -- to get your Netgear wireless-N USB device working.
Feb 25, 2010 | NetGear DGN2000-100NAS Router
HOW DO I INSTALL MY MOTHERBOARD DRIVERS ON UBUNTU. CD DOESN'T WORK, MOTHERBOARD IS A PC CHIP P23G V1.0A
Usually Ubuntu doesnt require any additional motherboard drivers if it has an open source version.
In Ubuntu 9.04, System> HARDWARE DRIVERS will show you all proprietary drivers in the system. You can ACTIVATE them there. Some files may be required to be downloaded from internet.
Oct 26, 2009 | PC Chips P23G Motherboard
Image Editor
I would recommend -- in line with the free software ideas of Linux -- The GIMP.
It's an amazingly powerful image editor. It should be installed with the default Ubuntu but, if it's not, it can be downloaded here: http://www.gimp.org/
Nov 24, 2008 | Canonical Ltd. Ubuntu
Ubuntu Support
Here is the website you really should see first:
https://help.ubuntu.com/
and about devices - they say it supports them, but personally I've never tried since I don't have any of those.
Sep 01, 2008 | Canonical Ltd. Ubuntu
Ubuntu sound problem
Hi Josh
First of all check system setting.
It seems like your modules are not loaded, if you just installed, I recommend you to
re-install Ubuntu, if this is not the case, try to run -
sudo apt-get -f install
If everything fails, try this - sudo /etc/init.d/alsa-utils start
Jul 29, 2008 | Canonical Ltd. Ubuntu
Brother P-Touch 1950 Label Printer Logo
15 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
