Question about Home
Showerselect manual termostat control how to adjust
How to change thermostat
The Termostat fit inside the Termostat Housing. It normally links to one of the radiator hoses leading from the engine block or radiator. Depending on the model you have, the termostat housing needs to be opened, the old termostat removed and the new termostat inserted. It's quiet simple. Before closing up, make sure that the both surfaces on the housing are clean and free from dirt and old sealant. If you remove a gasket, then replace with new gasket. If the housing takes a rubber O ring, then it is advisable to replace this.
Good Luck
Dec 29, 2011 | 2004 GMC Yukon
Inside my fridge there is a round manual termostat that is numbered 1...to 7 i like my fridge cold so what 1 would i have 2 have it on ..also up over the top of the door there is a button wit a pic of a...
firstly the button that turns orange is the freezer "fast freeze"control,you use this when you have defrosted it or move it to another house,the control in the fridge should be set so that the interior is at +2c to +5c,1 is the warmest 7 is the coldest,if you havnt got a fridge thermometer,do the lettuce test,if the leaves go black/soggy,its too cold.
Dec 22, 2010 | Whirlpool GB9SHKXL Bottom Freezer...
My 94 gmc sierra has no heat, new heater core and blower works, also has new termostat...any suggestions?
You Might want to Check your Heater Control Valve,Its located under your Hood between 1 Heater Hose and your Water Pump.Its Vacum Operated and could be manual as well.Have someone turn your heat on and Off while you watch under the Hood at the Heater Control Valve to See if you see it Move.Or could have a Leak.More than Likely its Frozen Closed not allowing the Hot Water to Run Through Your Heater ore ,Which Results in No HOT AIR blowing inside. Try This 1st.
Mar 01, 2010 | 1994 GMC Sierra
Clothes have burn marks
SOUNDS LIKE THE TERMOSTATS ARE FAULTY AS THE HOT ONE IS NOT CONTROLING THE HEAT TO THE ELEMENT AND IS OVERHEATING YOU NEED TO REPLACE THE TERMOSTATS .
Nov 17, 2009 | Cars & Trucks
Need to replace thermostat
USING A PAIR OF PLIERS RELEASE HOSE CLIP AND DISCONNECT THE HOSE FROM THE THERMOSTAT HOUSING LOOSEN AND REMOVE THE THERMOSTAT COVER BOLTS AND CAREFULLY THE TERMOSTAT COVER AND WITHDRAW THE TERMOSTAT FROM HOUSING REPLACE NEW TERMOSTAT ,RE FITTING IS THE REVERSE OF THE REMOVAL, BEARING IN MIND IN THE FOLLOWING POINTS ENSURE THAT THE THERMOSTAT IS CORRECTLY LOCATED IN THE HOUSING AND FIT A NEW SEALING RING .
Oct 24, 2009 | 1996 Volkswagen Passat
My freezer control in my ge side by side refrigerator is stuck
change the termostat that control temperature . is burned out. you need new one.
Apr 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator problem
The thermostat is only thing that controls temp. in your refrigerator...your right on the money!
Aug 12, 2007 | Magic Chef CTB1722 Top Freezer...
Problems
this is a manual defrost one what you mean cold? is there ice or not? if not then you may have a defective termostat and need to replace...good luck
Aug 10, 2006 | Whirlpool EL02CCXP Compact Refrigerator...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
