Question about Maytag Neptune MDE5500AY Electric Dryer
When drying it stop after awhile and it blinks all the time either h3 or he
One possible solution: My (ongoing) theory is that these dryers develop CONDENSATION in the electronics located in the control panel. I seem to be able to "cure" the problem, but it will eventually return and require another dose of "cure." It seems to me that it is a DESIGN DEFECT from the factory.
The "cure" (and I can't speak for all similar problems, but since this is easy and free, worth a try) is to take a BLOW DRYER and BLOW DRY THE CONTOL PANEL. Use HOT, but don't FRY the plastic of the control panel, but you will have to get it HOT, not just lukewarm. And it may take a while. At the moment, I have a small "office" style heater oscillating on the control panel because my arm got tired. However this SEEMS to solve the problem, temporarily, and makes the dryer work again.
I am working on a PERMANENT cure for this and will update everyone when I have established whether my proposition will actually work. But understand this: the actual cure will likely cost $0 and be able to be performed with common household items, if my intuition is correct on this. I will let everyone know when I do.
Posted on Jun 20, 2009
The 4 wheel drive light blinks most of the time then will stop for awhile then starts to blink agian
The light blinking is to get your attention , DTC'S diagnostic trouble codes stored to point Tech. to problem .
Feb 04, 2017 | Cars & Trucks
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Why the oil change light is blinking continue
it has to be reset. instructions in owners manual or internet
Aug 05, 2014 | 2006 Hummer H3
Why the light about change oil is blinking in the meter
U have 2 take it back 2 whomever changed the oil so the warning light can b reset!
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
TV wont turn on
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Aug 20, 2008 | Sony KP-41T65 41" Rear Projection...
Blinking screen
Power supply blown
This is often caused by a dry joint at C669 in the snubber network but also check the mains bridge rectifiers reservoir capacitor (47uF, 385v) for o/c, this item is not included in the ususal p.s.u repair kits and if not checked may result in a repeat blow up !
Nov 24, 2007 | LG 50PX4DR 50 in. Plasma TV
Maytag Neptune MDE5500AY Electric Dryer Logo
108 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
