Question about Toshiba TEC B-SX4 Thermal Label Printer
Skipping 1 mm (regular intervals) while printing labels
While printing labels (continuous), the labels are getting skipped. For example, when we try to print 50 labels continousely, after the fourth one the stationary gets skipped by a mm, then after another 4 labels this gets skipped again, and this goes on which makes the later labels useless.
Appreciate if anyone could help.
    An user who is expert in 3 categories / brands.
  • Toshiba TEC Master
  • 1,346 Answers
Re: skipping 1 mm (regular intervals) while printing...
1-try to recalibrate labels
2-make sure the label size is correct in the settings:
here is the link for the driver. :
Posted on Nov 09, 2007
0 characters
3 Points
Skipping labels
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
Nov 27, 2013 | Zebra 105Se Thermal Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Can't print continuous feed forms or labels without wasting paper
did you get this done.? I have the same problem, Lafayette,Indiana Realtor
Jun 24, 2009 | OKI Pacemark 3410 Matrix Printer
Datamax I-4208 not printing allocated amount of labels
Eventually you HAVE to give the printer a break, during inventory times at work, we have to print 50K+ labels, and in order to prevent either serial number skipping or other issues, I print in 250 batches, yes; there is a time gap but it's better than to restart a series of prints because a few numbers were skipped. Try printing 200 and 200 sets to prevent errors or skips.
Jun 03, 2009 | Datamax I-4208 Thermal Label Printer
Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
May 28, 2009 | Zebra 2746e Thermal Printer
Skipped Print Areas on Printouts
You may have a bad toner cartridge, if the cartridge has contaminants in it, it will not put toner on the drum in these areas, Try removing and giving the cartridge a good shake, try installing a new or at least another cartridge to see if the problem is here.
Hope this is of some help.
Apr 30, 2009 | Printers & Copiers
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
I get 2 labels(1 with data and 1 blank)for every label printed
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Toshiba TEC B-SX4 Thermal Label Printer Logo
1,042 people viewed this question
Top Toshiba TEC Printers & Copiers Experts
Level 1 Expert
Level 1 Expert
Are you a Toshiba TEC Printer and Copier Expert? Answer questions, earn points and help others
