Question about HEWLETT-PACKARD ProBook 6450b Notebook
Base system device driver in Elitebook hp8460p
Hi I need a recovery disc for my hp elitebook 8460p
You need to contact the manufacturer of the device for this, each disk is unique to the make and model.
Sep 23, 2016 | Windows 7 Home Premium Upgrade Home...
Hp elitebook 6930p webcame not detected
You can download the WEBcam and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 19, 2013 | HP EliteBook 6930p Notebook PC
Base system device
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
Feb 04, 2013 | HEWLETT-PACKARD EliteBook 2540p XT931UT...
PCI Slot 2 (PCI bus 35, device 0, function 1)
Download and install the chipset drivers
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Chipset drivers.
May 10, 2012 | HP EliteBook 8560p Notebook
I need a driver for unknown device on the HP elitebook 2530p
Just click the link below so that you will be able to download all the drivers you need.
Just click_here.
Sep 21, 2011 | HP EliteBook 2530p Notebook
I am having difficulty obtaining drivers O 3000 N100 OS XP Base System Device PCI bus 5, device 6, function 2 Base System Device PCI bus 5, device 6, function 3 Base System Device...
Base System Device drivers are usually installed by what the manufacturer calls "Chipset" drivers. If you are running Windows XP, there is an Intel Chipset driver available at the Lenovo Support Page for your model. If you are running an Operating System other than Windows XP, I would go to the above page and compare the drivers listed there with what you are seeing in Device Manager. Install the ones that are missing. Hope this helps!
Mar 09, 2011 | Lenovo 3000 N100 Notebook
I'm trying to connect my hp EliteBook webcam on ooVoo and I cannot. Is it possible that my webcam is not working at all?
Hi.
Based on the information you have provided, the issue might be due to the Webcam Driver or the settings.
However, in order to check if the Webcam is working fine, please try using the Webcam with any other Messenger Applications such as Skype, Yahoo etc.,
Also, please check if the Webcam Driver is mentioned in the Device Manager.
Please follow the below steps to check if the Webcam Driver is installed in the Computer.
1) Please press the "Windows Logo" and "R" keys simultaneously.
2) This should open the Run command window.
3) In the Run command window, please type "devmgmt.msc" and press Enter.
4) This will open the Device Manager window.
5) In the Device Manager window, please click on "Imaging Devices" and check if the Webcam Driver is listed under it.
By doing this we can confirm if the Webcam Driver is installed correctly.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | HP EliteBook 6930p Notebook PC
I get no sound out my speaker on my HP elitebook 6930p what's wrong?
1) Check the volume. With a laptop you normally have those FN key shortcuts to increase the volume. Check in windows as well. That speaker icon is the volume control. Try to look at that volume control since there is also a possibility that it is just muted.
2) Check if you have any icon that has an x or exclamation point in your device manager. the device manager is normally in your control panel > system > hardware tab > device manager
or you could open the device manager by clicking start then run then type in devmgmt.msc and press ok.
if you do have an icon with an x or exclamation point then there is a problem with your driver. check if that is your audio driver. if so, reinstall your audio driver or sound driver.
3) Try to use an external speaker or headset. See if you get sound from it. if you do then there might be a problem with the hardware already. if no, then its still software. check steps 1 and 2.
if you have any more questions and concern please fell free to leave a note. Thank you.
Apr 28, 2010 | HP EliteBook 6930p Notebook PC
HEWLETT-PACKARD ProBook 6450b Notebook Logo
15 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
