Teac w-750r double cassette deck stuck
Double cassette decl
  • Audio Player... Master
  • 1,267 Answers
The mechanism needs new belts and maybe grease cleaning and new applied. The dual cassette decks are not usually worth the charges a Technician will charge to fix them.
Posted on Aug 02, 2015
  • 9 Answers
SOURCE: Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Posted on Oct 27, 2007
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
ctf1800
  • 4402 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
Have you checked all the drive belts? Some dual decks use one drive motor and a long belt to drive both decks.
you also should be able to remove the cover of the tape compartment off to see the deck better
Posted on Feb 07, 2008
  • 579 Answers
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
  • 4234 Answers
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
Stuck cassette deck
I need a lot more info to even start- there are many decks made by that company that I once worked for. I fix the product all the time but model number is a start.
Jun 18, 2014 | Teac Audio Players & Recorders
I want my teac w600ro pla y deck a then deck b then stopyt
The unit needs work but it might not be worth repairing- that is up to you but most dual cassette decks were very poorly made units. That is why I always steer people away from them. I worked at Teac in Chicago and in fact still work on decks now under the skywave tape deck repair if you were to look me up.
Apr 16, 2014 | Beltronics TEAC W-600R Home Double...
How to replace the belt on a Teac W-750r cassette deck
In all the years I have been in tape decks repair I have never seen one. You either have to work with an experienced Technician or do it yourself using common sense. Going to college gives you a degree and knowledge of parts it dos not tell you how to fix anything. That may be why I work on some Nasa Engineers tape decks.
Jan 06, 2014 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Cassette clamp were to get one
Try Teac in California-
Parts Department
TEAC America
7733 Telegraph Road
Montebello, CA 90640
Phone: 323-727-4840
Fax: 323-727-7632
E-Mail: parts@teac.com
Jul 13, 2013 | Teac R-H300 Dual Cassette Deck
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
Jun 08, 2013 | Teac R-H500 Dual Cassette Deck
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
Teac Cassette Deck V-518X. No Record Audio.
Found a pinched wire under the cassette deck from the record head. Move the wire out from under the cassette deck. Works fine!
Thanks!
JOHN
Aug 05, 2008 | Teac Audio Players & Recorders
Older Teac cassette decks
I had an Aiwa dual deck and by the way your describing it, when you select Cont. Play press play on one deck then play on the other. I am not sure if there's a difference as to which you start with. When the first deck is done playing both sides, the unit will goto the second deck and play both sides, then back to deck 1.
Jul 01, 2008 | Audio Players & Recorders
Oct 08, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
210 people viewed this question
 Grubhead
Grubhead
