Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
No water from water dispenser
My water dispenser does not put out water. The icemaker is fine. Some time ago, the water began to take a little time to come out when the handle was pushed. Finally it stopped working altogether. Any suggestions?
    Sergeant:
    Champion:
  • 214 Answers
The valve or the outlet had been jammed. its an rare case. for this, wash out all the water from the dispenser and afterthat open it and fix the blockage.............
Posted on Jun 20, 2009
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Frigidaire FRS24ZRHW0 Icemaker/Water Dispenser problem
See if your water solenoid might be the problem. Your water supply line from the house will connect into a solenoid. I just recently solved a problem for someone on this site who had a solenoid that was sticking. Try tapping the solenoid gently to get it to activate or take it apart and depending on what type it is, manually move the spring loaded plunger a few times.
Hope this helps
Feb 25, 2010 | Refrigerators
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Ice maker does not work. Has worked fine until about a week ago
Mine has done this several times. There is a switch, usually in the tray above the ice container at the back. Move the switch to the OFF position for about 30 seconds. Now, turn the switch ON and push it hard in the ON position for about 30 seconds. This will 'jump start' your icemaker going again and you shouldn't have any more problems.
Mar 30, 2009 | Refrigerators
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
