Question about Cell Phones
Top Up I want to top up my simcard
How do I top up my phone for texing
Depends on the type of simcard you have. Sounds like you have a pay as you go simcard
What network are you on?
Normally you can go to a newsagents or somewhere that sells top ups, ask for £__ top up for __ network
Call your network provider and type in the code given on the receipt.
If you tell me your phone network I can be more specific!
Or show you alternative ways of doing it
Mar 15, 2015 | Samsung GALAXY S4
Phone shows no sim mode even when the sim card is in
Try folding a little paper a couple times then put it on top of the simcard and then put the battery on top of that.
Also make sure you put the simcard in the phone the correct way (look at the image and the cut of corner)
Mar 23, 2012 | Samsung Propel A767 Cell Phone
When i put the sim card in to the phone and try to top up it says no network cover
Dear Isabella
I am back for a few days. I am sure that you have topped up your phone by now. Or got a new simcard.
All the best
kolbrun
Nov 09, 2011 | Nokia Classic Cell Phones
Phone get automatically restarted with the following message 'Sim removed phone will be restarted'
Hi
seems like your simcard stay loose in your phone. Gently press the metal piece that your phone have on top of simcard.
thank you.
Sep 15, 2011 | Samsung S5620 Cell Phone
My motorola razar2 V8 mobile is when switched on it shows "unregistered sim" earlier it was working fine. The same sim is working in other set. Pl do guide to solve the problem
check the simcard reader pins if it's align or bend the brace on top of the simcard so it fits and hit the 6 pin along the simcard interface.try to clean it as well.
Jun 26, 2011 | Motorola Mobility RAZR V3
When I call someone the tell that network fail
hi there!
try calling other numbers on your phonebook, also check if the signal bar (on the top left of the screen) is full. load or minutes on your phone must be enough to make calls aswell. if all these passed and you cant still make calls, try using other simcards, if you can call using other simcards with no problem, you have to call your telco so they can check on the call settings of your simcard. if you cant make calls using other simcards too, try to remember if you have changed some settings on your phone or download an update and let us know! =)
Apr 12, 2011 | Nokia 6300 Cellular Phone
"sim card registration failed" will
is this happens to other sim you inserted on your phone...if still occurs it seems you have a loose simcard socket..or the copper contact itself miss a connection...
try to clean your sim esp. the copper surface also do the same in the simcard slot..
put your sim and gently apply force or put a ply of paper on top of the sim and close the phone cover. turn ON your phone and check if the sim already register....nice day
Feb 12, 2011 | Computers & Internet
I need the default puk code for the lg ks360 please? i never enterred a puk code, but i wanted to enter one and it told me to enter the old puk code, everytime i try a number i can think of it says its...
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
Jan 09, 2011 | LG KS360 QWERTY Keyboard Phone BRAND...
I phone no sim
try removing the simcard from the iphone by inserting the end of a paperclip into the small hole at the top of the i-phone, this will push out the simcard. Then clean the simcard and re-insert it into the phone, the issue should now be resolved. if it persists then it could be because you have a faulty simcard in which case take your i-phone to your nearest apple/o2 store and they should give you a replacement.
Feb 24, 2008 | Apple iPhone Smartphone
Blackjack no sim card or simcard error
I had the same issue, cleaning the contacts on the sim card did not help. BUT i went and got a new SIM, it did the same thing.. till i wedged some folded up paper into the sim slot on TOP of the sim card forcing it closer to the contacts. So far this is working for me atleast. good luck.
Jun 18, 2007 | Samsung Blackjack SGH-I607 Smartphone
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
