Question about RCA L32HD31 32 in. LCD HDTV
I just purchased the RCA model L32HD31R. Everything works fine except that I can't remove the analog channels from the list. I get my signal OTA so no cable or sat issues. I go into the List Menu and they are all unchecked. It worked fine right off the bat and then it suddenly added the analog channels. I have tried unplugging the antenna and rescanning...still does it. I unplugged the unit and left it unplugged for 10 minutes hoping it would reset..it didn't. I just want to be able to hit the channel button and not have to scroll through multiple analog channels to get to the very few digital channels I get.
  • goatscrumpy Jun 20, 2009
    Umm..yeah, sending a link to RCA doesn't really help unless you can be a little more specific. Been there and have the user guide sitting in front of me.
    Thanks though.
I had the same problem and finally sloved it. You have to leave the input channels ( Vid1, Vid2, SVid, Cmpt, HDMI, etc ) in the In Channel List. So push the INPUT button, go to VID1, press Menu, go down to List & Labels then check In Channel list. Do this for all the inputs and then run your Channel search again. I hope this works for you. It did for me.
Posted on Jun 24, 2009
  • Vdloyd Jul 18, 2011
    Do you have any suggestions if we do all of this and still don't have the digital channels?
  • 37 Answers
Link to RCA
Posted on Jun 20, 2009
I have serial #107611268,model # f27668,classic #ctc203aas..i need to change from cable to antennae and can nit get any channels to list
This is an analog tuner tv,there are no OTA analog tv transmissions you need a digital converter box btween your antenna & tv
Aug 02, 2013 | RCA Televison & Video
How do I program a universal remote to an RCA Model L32HD31R
This is the general setup proceedings to a universal remote control.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the dropdown list by the 'Sidebar' of the display window. It will make search easy.
Mar 12, 2013 | RCA Televison & Video
WILL RCA DVD/RECORDER, RECORD MOVIES FROM TV TO DVD DISC
It depends on the model and the source. The DRC212N is not a recorder, so it won't.
Depending on the model, it may or may not have a tuner. (Most modern ones are sold without any tuner. Older models may only have an analog (NTSC) tuner.) I know of one Magnovox DVR/DVD recorder that has an ATSC (digital) tuner.
If you are going to record OTA signals, you will probably need a digital to analog converter. If you are recording from a cable or satellite system set-top box, you need to set the channel on the box and then record on Line In. (Analog cable should record directly.)
Please add a comment with more information about your DVD recorder. I'll be glad to provide more assistance. I hope this helps.
Feb 03, 2013 | RCA DRC212N DVD Player
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Digital or Analog
This TV has an NTSC (analog) tuner. You'll need a digital to analog converter if you want to receive most OTA channels.
I hope this helps.
Apr 25, 2010 | RCA 32V550T 32" TV
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. surfpro@yopmail.com
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Jan 06, 2009 | JVC AV27F476 27" TV
RCA L32HD31 32 in. LCD HDTV Logo
1,899 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
