Question about Hammering
Remove motor challange xtream 18volt - Hammering
Milwaukee 18volt cordless drill pull trigger motor bogs. Pull trigger motor speeds up and bogs down again, could it be bad switch or motor?
Most likely it is either dirt or a burned spot on the armature of the motor. I would try blasting it with air to see if you can clean it out. If that doesn't work then it probably needs to be torn down to either clean it or replace whatever is damaged.
Nov 02, 2015 | Milwaukee Drills
In what years did Chevy make xtream s-10's
It is all on the internet. Look it up . Don't expect others to do simple research for you.
Dec 25, 2012 | Cars & Trucks
I have a T71 treadmill the motor will shut off fairly quickly after starting. It seems to happen as it is accelerating. The time and other treadmill elements will keep going as if the treadmill is...
take hood off and take the wires from the motor. the ones that power go through, and test with a fully charged cordless drill one at least 18volt that should run your motor . not fast but it will cycle.if motor runs then its the controller board
Mar 18, 2011 | Exercise & Fitness
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Mar 16, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
My coleman 18volt PMD8133XL drill smokes and has a burning smell when oressing triger
Hello, I hate when this happens to my tools. This could be a number of issues. I would think that the transistor that controls the motor speed is shot or the motor itself is loading the transistor causing the smoke, or the brushes internally of the motor are worn and causing the overheating, hence smoke. Is the unit new or well used?
Joe
Jan 09, 2011 | Coleman Cable Coleman 18 Volt Combo Drill...
Pro tech 18volt. Item number 6810
http://www.sears.com/shc/s/p_10153_12605_00981808000P?vName=Tools&cName=PowerToolAccessories&sName=Batteries%20and%20Chargers&psid=FROOGLE01&sid=IDx20070921x00003a
Mar 27, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Xtream card memory 256 MB
I have never heard of this scenario before and it is highly doubtfull but if you have a virus.... But if you do...
Connect you camera to your PC (via USB or cradle)... This should add a new external drive... Scan this drive with your anti-virus checker and remove the virus...
If you have a card reader, remove the memory card and insert it into the card reader and repeat the above steps...
Nov 09, 2007 | Compaq Easy Access Smartcard Keyboard
Hammering Logo
78 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
