Who makes veon tv
I have a veon 58inch tv and every now and then a red square appears on the bottom left of the screen. Any idea why this happens.
marked
  • 6487 Answers
SOURCE: unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Posted on Jul 20, 2008
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
i need to unlock my tv
Posted on Dec 05, 2008
  • 126 Answers
SOURCE: My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Posted on Jun 04, 2009
  • 245 Answers
SOURCE: a square red warning light appeared on the dash
water tempechor antifreeze is low or getting hot or your electric fan is not coming on
Posted on Jan 25, 2010
Testimonial: "This was very helpful and will save on repairs"
I have a Veon TV/DVD . I want to hook it up to a Samsung VCR/DVD player . if I want to play a video what channel on the veon TV do I play it on. Or is there something I am doing wrong Julie
Hi if U r using 3 RCA cables RED WHITE ,& YELLOW connect them to the input sockets on TV red is audio & white is audio yellow is picture then set the TV to AV .. INPUT.cheers
May 14, 2016 | Samsung Televison & Video
My Veon 32'' tv wont turn on
Usually fuse near cord interior in case. Teardown. Careful..VOLTAGE danger even unplugged. Touch nothing else.
Apr 17, 2016 | Televison & Video
Veon tv
then you should probably buy one
Jul 04, 2014 | Computers & Internet
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
Hi! I'm trying to download photographs from my camera, everything shows fine in the thumbnails in the software window, but the "Quick Preview" icon in the bottom left has a red square, and if I...
Pros avoid these kinds of problems by using a card reader and dragging and dropping to a folder they create on the desktop. From there, you can send the pics to the software. typrice_161.jpg
Apr 04, 2011 | Canon EOS Rebel XSi Digital Camera
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Recalibration
  1. Remove all games from the Nintendo DS Lite.
  2. Turn the system on by pressing the POWER switch.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • If the above steps did not help, there is a problem with the system and it will need to be repaired. Click here for repair options.
  7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
  8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Nov 02, 2007 | Nintendo DS Lite Console
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
