Question about Minolta DiALTA Di183 Copier
I want my copier to start printing - Minolta DiALTA Di183 Copier
  • Minolta Master
  • 6,161 Answers
What Operating system are you using I believe that Di183 at best can use windows 95 at best XP? have the drivers been installed in your computer free at KonicaMinolta if they still have them.
Posted on Dec 29, 2014
DATA LIGHT FLASH BUT NO PRINT OUT IS COMING SHARP MX2300 N
Watch this video on how to perform an image memory clear on the sharp.
on your model you'd start by pressing # * C *, then 66 start, 10 start, execute, yes.
Copier Collin Houston TX Copier and Imaging Expert
May 30, 2013 | Sharp MX-2300N Color Copier
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
Dark print out
check the fuser... to see if one of the rollers has toner all over it... then check your paper path... to see if you see any obvious signs... then try printing 20 pages and opening the copier at various times during the printout process... you want to see if you can catch it where the dark starts appearing... chances are where it starts... is right next to the bad part... you are looking for a print out with one half no dark and the other half real dark...
Dec 16, 2009 | Canon NP 6035 Copier
Checks printing in reverse order
Generally speaking, there is a setting on your print drivers properties to print reverse order. Start, Printers, right click on your printer, go to printing preferences and it should be there.
Aug 28, 2009 | Sharp AR-5320 Black and White Copier
My KODAK PRINTER ESP3
it is a problem with print spooling. and the firmwware also needs to be upgraded of the printer . click on start, go to run,type services.msc in search boz of run. find print spooler,right click it,stop it and then start it. click on apply and the ok. Go to control panel,printers and faxes ,set ur printer as default printer.try to print after dat ur issue will be resolved
Jul 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
Minolta DiALTA Di183 Copier Logo
16 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
