Question about Nutrifaster Juicers
Unit smoking from underneath, overheated or motor gone?!
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Juicer want start
Dear Julmo,
please get it to any authorised service centre so that they can fix it accordingly, see if the motor is gone the maybe they just replaced it ,if you wanna try to fix it then it may cause more complicated.
takecare
Mar 25, 2008 | Jack Lalanne Power Juicer 250 Watts
Motor may be burned out; juicer does not turn on
If you saw smoke, likely the motor may be burnt. A bit late!
Mar 23, 2014 | Waring JEX 328 Health Juicer
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
The motor stopped while juicing hard veggies and doesn't work any more even after the engine cooled down. again. How to fix it?
There may be an overload switch somewhere on the unit, it will just be a small button projecting from the underside most probably or in a small hole. If there is, just depress it. If the unit actually burned out yu would have seen smoke and smelled it.
Jan 21, 2011 | Breville BJE510 900 Watts Juicer
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
Don't know how to set up Jack lalanne power juicer
First, check that the switch is in the on position. Then, check that all parts are assembled properly. The unit has a built-in safety device that will not let the motor turn on if not assembled properly. The Power Juicer also has a built-in Thermal Cut Off Safety Switch. If the machine was running, then shut down due to accidental overheating, then there is a 10 minute cooling time before the machine will restart. This helps to protect the motor from seizing. Click on the link below and select your juicer model to view the instructions and operating manual
http://www.powerjuicer.com/customer-manuals.html
Apr 15, 2010 | Juicers
Leaking dark fluid from motor when juicing
sounds like the start of a horror movie. lol
ok dark? and no cracks or leakage from the juice container? hmm
dark .... ...its gotta be juice leaking down and mixing with the dark grease they use on the bearings.. but this is a wild guess. and i cant think of anything else unless a 100 roaches live inside the motor housing.
get it fixed when it starts to whine or smoke.
Apr 03, 2008 | Champion 2000+ Household Juice Extractor
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Juicers Logo
Top Nutrifaster Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
