Question about Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet washer
What does it mean when washer says h f?
    Brigadier General:
  • 8,619 Answers
Hi
This error code means that there is no water detected entering machine or Pressure switch trip not detected. Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
What are the numbers for in my dispenser on my Whrilpool waher model LMH0050PQ
Can not locate your model number please recheck it I found LHW0050PQ and the drawer is seperate from the handle you would have to change the handle over and keep the internal componants as well. That part number is 8182370
Jan 28, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have whrilpool front loader, when washing some times I get a error F70 & F71. The washer stops, clothes are not rinse alaway. What can I do. I don't have my munual handy. Thanks for your...
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whrilpool duet is lockt on control... I can not change, cancel or do anything, The only light on the waser is 'Controle 'Loocked'
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
My Whrilpool Duet keeps "eating socks", I have to take the cover off, unscrew the drain trap and pull out yucky, smelly socks!
That is a common problem with the Whirpool duets. Small clothing articles, especially baby socks go through the drum lip to the drain pipe.
Best to buy a zip-up laundry bag and place all the small clothing items in there.
Best Regards
Ash
Nov 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
UR MAIN CONTROLLER NEEDS REPLACING. IT HAS A COMMUNICATION ERROR
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mold? behind seal on whrilpool duet front load.
Run it a couple times on hot water with bleach in it. Should help. Also run through with dishwasher detergent in it. This helps clean too. I leave door ajar to allow air in washer. You can also purchase cleaner just for this at parts place.
Nov 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
